Enthusiast ![]() ![]() ![]() Joined Sep 6, '03 From hudson ,iowa Currently Offline Reputation: 1 (100%) ![]() |
i am turboing and i am looking into a t3 , i plan to run a max of 8psi and i was wondering how a t3 will work ,
Enthusiast ![]() Joined Jul 24, '04 From Va Currently Offline Reputation: 0 (0%) ![]() |
A T3 would work but I believe that it would be too small for a 2.2L 16v. I'd go with a T3/T4 hybrid or a GT28RS.
thats what i was thinking , but some say the t3/t4 is to much cause it designed for high power cars i thoughe, i also want the quik spool up of the t3
A T3 super 60 will probably be your best choice then. It wont have as much in the upper RPMs though.
Considering alot of ppl use the CT26 the T3 should do u fine.
![]() Enthusiast ![]() ![]() ![]() Joined Sep 22, '03 Currently Offline Reputation: 0 (0%) ![]() |
I have a t3 with a trim of .45..
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) ![]() |
T3 will be perfect if you're not looking for high high horsepower numbers. Check it's compressor chart and make sure it matches ur interests
all i want is a fast spool for about 8 pounds of boost ,
You'll get it
get .45 trim..
![]() This post has been edited by hyp3rk1d: Jul 28, 2004 - 10:46 AM |
Fast spool with 8lbs, honestly i'd recommend a CT26. Find a JDM one with a ceramic wheel which will enable faster spool up and stock pressure is 8 so ur good to go, and then you can even upgrade the trim to 45 - 50.
Cheaper too |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) ![]() |
i love my T3 turbo
![]() -------------------- yea your 3sgte is cool but ill stick to my 7agte
get the t3 with a 45 trim..
Lo-Fi Version | Time is now: February 20th, 2025 - 12:15 AM |
