![]() Enthusiast ![]() Joined Apr 17, '04 From Southern California Currently Offline Reputation: 0 (0%) ![]() |
i am just curious. when i first bought my used celica .. the radio and everything was missing .. i took my car to best buy to get a head unit installed n' ish and they said that my stock radio harness is missing.. they still got the radio/cd unit to fit and everything.. but i want to find a replacement for it
http://store.yahoo.com/americanesuperstore/99-8201.html or http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...5711843765&rd=1 will those fit for my 94 celica ?? -Thanks This post has been edited by yellowxboy: Jul 28, 2004 - 7:21 PM |
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
Those are just install kits, which you don't appear to need. For the harness, you'll need to go to a junkyard and find any wrecked Toyota from '88 or newer I think, and cut off the stereo harness. Then you'll solder that onto your cut wires on your car, and buy a Toyota stereo wiring harness from Best Buy or wherever and then solder that onto your deck harness, then it all plugs together.
When I had my friend install my cd player way back in the day, he cut off my stock harness and crimped everything together. A few months ago I finally got around to fixing it, just for peace of mind and easier installs and stuff. It's well worth it, and the guy at the junkyard just let me take the harness after I cut it out of the car. -------------------- New Toyota project coming soon...
maybe i worded it wrong. sorry for the confusion Coomer. maybe this pic will clear up wut i'm tryin to ask..
i'm not lookin for the wires.. maybe its called the 'stereo harness?' where the white arrow is pointing.. i think i'm missing the part that holds onto the cd/head unit. what is that call ?? |
Are you talking about the little metal brackets on each side that hold the extra slot and the head unit together and in place?
bingo! is there a name for it ?? its wutever that holds the entire unit/free slot
This post has been edited by yellowxboy: Jul 29, 2004 - 1:36 AM |
Enthusiast ![]() ![]() ![]() Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) ![]() |
Salvage yard, almost any Toyota radio from any car with a double DIN opening will work, was looking at an Avalon the other day, same exact factory stereo as my Celica, and depending on your car, they may have just missed it, if yours had an external amp from the factory, your car harness plugs into that, (mounted low on the center hump, behind the climate control, 2 blue plugs on the bottom side) and there was a single white plug from the amp that went up to the radio
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 27, '02 From Derry,NH USA Currently Offline Reputation: 9 (100%) ![]() |
All you have to get is get the color coding for the deck and the car and match them up. It's not very hard at all if you know how to twist and splice wires.
Lo-Fi Version | Time is now: February 23rd, 2025 - 9:40 AM |
