Axle removal/installation, a few questions... |
Jul 28, 2004 - 10:27 PM |
Enthusiast Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
I started taking off my axles today because my CVs were busted. I got the passenger side off fine, but im having some trouble with the divers side. Does the axle just come out, or am i missing something? Ive tried prying it out with no luck. The axle came apart and this is what i have left to pull out.
Another question is does out tranny have a drain bolt? Alot of fluid came out and i want to replace the gear oil. Thanks -------------------- |
Jul 28, 2004 - 10:38 PM |
put your car in nuetual and have the other front wheel off the ground.. then pry it out.. MAKE SURE YOU CHANGE THE AXLE SEAL. the thing that seals the gear oil in the tranny where the axle goes in..
Jul 28, 2004 - 11:35 PM |
that pic is what ive been dealing with for the past week.
on the tranny there are 2 large bolts...one is for drain and one is for fill. undo them and drain your tranny oil out. then get some type of thick pry bar and keep prying on it from all sides till it pops out. ....it may take a few min before it comes out. if you end up having to buy rebuild axels, dont buy them from any place that sells rebuilds by CCT... ive had nothing but horrible luck with them. i had them orderd 3 times and none of them were right. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 28, 2004 - 11:36 PM |
Looks like you pulled the axle apart... in a sense... mostly broken. It'll be most cost effect now to just replace it. Also, there is a drain bolt on the tranny... I believe it's on the side... I can't remember exactly where.
-------------------- "It's ok to be naked girl... I'm an artist!"
Jul 30, 2004 - 1:32 PM |
after getting 3 messed up axels from autozone (aka CCt axels). i ended up getting a rebuild through Carquest. i highly recomend them...the axel looks better then my oem one. i didnt drive the car yet, but i doubt that this axel will give me any problems.
Jul 30, 2004 - 2:22 PM |
Well i already baught axles before i started this project, and guess who they were rebuilt by?
I got the old axle out, and im assuming the new one just goes back in the same way... is that assumption correct? I have givin it everything i can but it just wont go. Any suggestions? And yah the drain and fill plugs are the big 15/16 inch bolts sittin there on the tranny. Thanks This post has been edited by mikew04: Jul 30, 2004 - 2:23 PM -------------------- |
Jul 30, 2004 - 5:22 PM |
try using a old fasioned lug wrench as a pry bar, thats what the toyo manual shows, worked perfectly for me, after i tried with just about everything else laying around the garage!! lol
13.6@108MPH, 5SFTE Powered |
Jul 30, 2004 - 5:38 PM |
That helped when i was taking it out, but theres really nothing to brace it against when trying to get it back in. its that damn ring at the end that has to snap into place inside the tranny. ahh this is killin me and i need my car back...
EDIT- lagos, did you order the axles and they sent you the wrong ones? or did you put them in only to have them fail on you? This post has been edited by mikew04: Jul 30, 2004 - 5:40 PM -------------------- |
Jul 31, 2004 - 2:41 AM |
Enthusiast Joined Dec 4, '03 Currently Offline Reputation: 0 (0%) |
take a block of wood, like a 2x4 and put it against the axel hub and then knock it with a hammer. thats how i put mine in when i did my transmission swap. make sure you lube up the gearing threads on the axels before you put them in.
-------------------- hows it taste motha f*cka
Jul 31, 2004 - 7:07 AM |
doubble check that they sold you the right axel!!!!!!! you can do this by counting the splines on the axel and the tranny. best way to put them in is to.....have the snap ring facing down....put the axel in the tranny and move it around untill you feel the splines match up and you can turn the axel and hear it doing something in the tranny. then take a long flat piece of metal (i used a long file) and put it at the sides of the axel (you know...those grooves that stick out of the part that goes into the tranny) ...use a hammer to tap each edge in, untill the axel goes in. after you put everything back together, take a look at the 2 boots as your are turning the rotor. make sure they turn correctly and boot isint doing anything odd looking. like i said before...you have no idea how bad CCT is....make sure they sold you the right axel....or better yet, return it anyway and go with carquest. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 31, 2004 - 1:37 PM |
Alright thanks for all the help guys, i got it in and it seems to be ok. no more clicking noises at least. That job was such a pain (even worse than replacing the headgasket on my old car) but im glad i got it over with and i just hope everything holds together haha.
Lo-Fi Version | Time is now: November 28th, 2024 - 9:18 AM |
