Does any know if....? |
Feb 26, 2003 - 3:35 AM |
Does anyone one know if the engine parts made for the 4AG can fit ni to 7A FE??
Feb 26, 2003 - 3:39 AM |
another question does anyone know if the 7A FE can handle an 11.0:1 compression or higher.
Feb 26, 2003 - 5:00 AM |
Enthusiast Joined Sep 27, '02 From UK Currently Offline Reputation: 1 (100%) |
The answer to your first question is:
You can do a 7A-GE or 7A-GZE conversion using a 7A-FE and an 4A-GZE. It's basically a 7A bottom and 4A-GE 16V head. For more information and details take a look at this link http://www.corollaperformance.com/Mods/Eng...ngine/7AGE.html. |
Feb 26, 2003 - 4:32 PM |
Enthusiast Joined Oct 1, '02 From North Bethesda, MD Currently Offline Reputation: 0 (0%) |
um, how about not. unless you want to spend about 6-8 grand on a 7age, don't do it. you have 3 options. 7age - will net you about 120 HP at the crank 7agze - probably about 150, but at great expense 7agte - really the only way to go, but very very $$. to run a 7agze or 7agte, you will need a standalone EMS (1.5-3K), custom forged rods (about 1K), custom alternator bracket, custom a/c bracket, you will loose power steering, and that's not even scratching the surface. practically, unless you have a 7afe and 4agze just laying around to play with, don't do it. the guys who are discussed in that article had engines laying around to use. if you know what you are doing this swap will take about 2 weeks of solid work to do. can you really go without your daily driver for that long? As to the 4age question, you can use pistons and rings for a 4age in a 7afe block. that's about it. -------------------- 1994 Lexus ES300
1989 Supra Turbo 1990 RHD ST185RC - JDM Spec |
Lo-Fi Version | Time is now: November 24th, 2024 - 1:45 AM |
