> Speedometer is off, I just changed my tires....
post Feb 26, 2003 - 10:22 AM
CelicaQT
Joined Sep 29, '02
From Sterling Heights, Michigan
Ok I need some info any of you guys/gals can give me. I just recently changed my tires bcus I wasn't getting any traction or handling on them during this winter season. Plus they were getting bald. I went from a 205/50R/15 to a 205/50R/15 and I read that your speedometer may be off?? SO I was wondering if anyone would know how to calculate how much I lost going to a lower radial?? Doing 80 on the freeway seems like i'm only going 70-75mph or doing 25-30mph doesn't seem like the actual speed either.
I got Yokos on them I was supposed to get Toyos ....long story....but regardless the handling and cornering on them is a lot smoother than my old worn out tires. Could it be that I'm just getting used to the new tires?
post Feb 26, 2003 - 11:04 AM
94TRDCeli
Joined Jan 29, '03
From Texas
dude you realise that you said you went from one tire to the exact same tire
post Feb 26, 2003 - 11:06 AM
CelicaQT
Joined Sep 29, '02
Ohhhh oops..mah bad. I ment I had a 55R then went to a 50R. SOrry...i didn't realize it.
post Feb 26, 2003 - 11:13 AM
CelicaQT
Joined Sep 29, '02
Ok well I think I mighta figured it out. I think the speedo differs when/if I'd be going to a bigger rim size. But since I'm still on 15's then maybe I'm just off by maybe 1 or 2.
post Feb 26, 2003 - 12:05 PM
3TST
Joined Sep 27, '02
From UK
205x50x15 is the standard size so your speedo reading should be pretty accurate.
However, if you went for 205x55x15 then the speedo will be out but not by much. (sorry not sure how to calculate this).
post Feb 26, 2003 - 3:34 PM
95STCelica
Joined Oct 12, '02
From New Jersey
Speedometer reading : stock tire is 3.5% too slow..when your speedo reads 60 mph you are actually traveling 62.1
post Feb 26, 2003 - 4:09 PM
CelicaQT
Joined Sep 29, '02
I found out that with the new tires on (50R's) that I'm going 3.29% Fast.
My friend told me to go to 7thgencivic.com and they had a Tire Size Calculator on their site.
going 60mph x 0.0329 = 1.974
So like 2 miles over...
post Feb 26, 2003 - 4:53 PM
Milds3vn
Joined Feb 11, '03
From Phila, PA
Check this out to calculate any size changes... http://www.miata.net/garage/tirecalc.html
post Feb 26, 2003 - 5:03 PM
CelicaQT
Joined Sep 29, '02
LOL ok I was told that also. Man seems like all of these tire calculators vary. It's hard to tell which is accurate.
post Feb 26, 2003 - 11:53 PM
95STCelica
Joined Oct 12, '02
From New Jersey
QUOTE (Milds3vn @ Feb 26, 2003 - 2:53 PM)
that's what i used
post Mar 7, 2003 - 8:02 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
Just set your cruise for 60.
When you hit a mile marker, start a stop watch.
In exactly 60secs your should pass the next marker.
If you don't then use D=T/V to figure your speed.
post Mar 7, 2003 - 3:45 PM
CelicaQT
Joined Sep 29, '02
Thanx for the info though...
post Mar 7, 2003 - 9:22 PM
95STCelica
Joined Oct 12, '02
From New Jersey
post Mar 11, 2003 - 7:18 PM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
My ST came with it, so biggrin.gif for me!
post Mar 12, 2003 - 12:17 AM
Zoom
Joined Oct 15, '02
From Rochester, New York
http://www.c5-corvette.com/tirecalc.htm
one more calculator;). I like because it also shows the odometer error, which is nice.
This post has been edited by Zoom: Mar 12, 2003 - 12:19 AM
post Mar 12, 2003 - 10:06 AM
CelicaQT
Joined Sep 29, '02
I actually like that site better! It's got more info than the other sites I've gone to. Thanks Zoom. smile.gif
post Mar 12, 2003 - 2:25 PM
SpedToe169
From Dallas, Tx
Even with the stock size tires its still not very accurate. I've got GPS thats accurate to 0.1mph. Even with the stock size tires and wheels its about 4% off.
post Mar 15, 2003 - 12:15 PM
95STCelica
Joined Oct 12, '02
From New Jersey
post Mar 24, 2003 - 8:48 PM
hioctane
Joined Nov 26, '02
wow only 1.6% off with gts rims =)
post Mar 25, 2003 - 7:19 PM
Zoom
Joined Oct 15, '02
SpedToe, with stock, is 4% off a high or low reading?
Lo-Fi Version Time is now: February 17th, 2025 - 11:46 AM
