> For those with subwoofers...
post Jul 30, 2004 - 6:36 PM
Sh0gunkid8721
Joined Feb 22, '03
Where did you put the ground???
I wanna relocate my ground since its in a sh*tty area.
post Jul 30, 2004 - 6:43 PM
QUOTE (Sh0gunkid8721 @ Jul 30, 2004 - 4:36 PM)
One of my grounds for the amp in the backseat side panel is where the passenger side rear seat belt bolts to the car.
For the other amp in the trunk, I'm just sanded down some of the painted metal right inside the little carpet flap door things and put a bolt through a hole with a nut on the other side, and the ground terminal in between there.
Both of my grounds work fine...make sure that you sand down to the bare metal for the ground. It's also better to use different ground points for different amps. smile.gif
Lo-Fi Version Time is now: February 22nd, 2025 - 10:18 AM
