3 bar map sensor |
3 bar map sensor |
Jul 30, 2004 - 11:43 PM |
Enthusiast Joined Jul 31, '03 From Panama City Beach, FL Currently Offline Reputation: 1 (100%) |
today i found out the price of a 3s-gte 2 bar map sensor cost (not good). i found a 3 bar map for a decent price. would a 3 bar map sensor work on a 7a-fte setup? is there a 2 bar map that would work that isn't outragously priced?
thanks. |
Jul 30, 2004 - 11:55 PM |
I dont see why the 3bar would work any more or less than the 2 bar, just has a bigger range.
Jul 31, 2004 - 1:23 AM |
Enthusiast Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
It will cause you to run way to much fuel. A supra 2.2bar has been tried and still doesn't work.
-------------------- Member of Team 5sfTe
Jul 31, 2004 - 12:13 PM |
damn, any other alternatives?
Jul 31, 2004 - 11:00 PM |
Enthusiast Joined Dec 2, '03 From Virginia Currently Offline Reputation: 0 (0%) |
You probably con only use one designed for that application. A 2.2 bar map sensor will have a different calibration curve then just a 2 bar, so at a given point the voltage drop of the sensor may be higher or lower then the ecm is expecting. Just as a toyota 2 bar may have a different curve then a ford 2 bar and they are not interchangable.
Lo-Fi Version | Time is now: December 2nd, 2024 - 6:48 PM |
