> Lowering Woes, And shock questions
post Nov 12, 2002 - 8:54 PM
Before my car went into the body shop, I had some super high coilovers installed on it. They slammed the car so that it was probably about 2-2.5" below stock height, and the ride was really bouncy and bottomed out on everything. Last night I raised it up once I got the car out of the body shop, so now it's about stock height. The car doesn't bottom out, but the ride is still pretty bouncy though. It's definitely a lot bouncier than stock, even though it's about at stock height. It makes me wish that I hadn't lowered the car at all in the first place, at least not until I could afford new shocks to handle the drop.
I want to get some new shocks fairly soon, and I was considering Koni Yellows, so I did some research and found that they cost $300-400 just to install them! I was wondering if any shock is going to cost that much to install, or if it's just the Konis. Also, is there an alternative to the Koni Yellows that provides close to the same handling, but without adjustability(Or the higher price tag.) Thanks!
post Nov 12, 2002 - 9:25 PM
west_minist
Joined Oct 27, '02
From Barbados
Your prob. is unique to some point.
It sounds like the installation is part of the price, who knows.
Did you call a dealer?
Have you check out www.kyb.com shocks. There are also very good.
KYB GR2 (LF+RF) #365092 ($42 per)
(LR+RR) #334125 ($62 per)
It seems that the cost includes everything.
Try to find out from them what this cost is all about.
Additional reading:
http://coximport.com/kyb/t.html
http://www.kyb.com/catalog/index.html
All info is there for your model.
West_Minist
Hydra EMS Dealer & Tuner
Subaru ECUFlash Tuner
http://www.socob.bb
http://xtremeracingtuning.com
Viciously Tuned, Driven Hard
post Nov 12, 2002 - 9:49 PM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE (west_minist @ Nov 12 2002, 07:25 PM)
Additional reading:
I am also looking into shocks. Thanks that was very helpfull.
-Bryan-
Member of Team 5sfTe
post Nov 12, 2002 - 10:58 PM
Cragspider
Joined Aug 30, '02
From Franklin,Tn
Ok note to every body. The stock struts are KYB's. I noticed that when I was putting on my coilovers this past weekend.
Bryan.
post Nov 12, 2002 - 11:01 PM
trdcelica99
Joined Oct 21, '02
From florida
are the super highs the ones on ebay that are blue that run for about 65-85 dollars? is it possible that the bounciness is caused from the coilovers? biggrin.gif
post Nov 12, 2002 - 11:40 PM
JWalk1818
Joined Aug 30, '02
From North Carolina
Ok Well I have doen the most terriable thing LOL and cut my springs. I have almost a 2 " drop on the front and a 1.75 in the back. Ok well this weekend not to CRACKon Brain or anythign but I noticed him bouncing pretty bad, actually worse thand me. So my ? is are the coilovers worth it or not since the ride is bad! rolleyes.gif
99 Toyota Tacoma
post Nov 12, 2002 - 11:53 PM
QUOTE (trdcelica99 @ Nov 12 2002, 09:01 PM)
Yes, those are the super high ones. It could be caused by the coilovers, but I'm guessing that it's my stock struts with almost 96,000 miles on them. Thanks for pointing that out.
post Nov 13, 2002 - 8:08 AM
west_minist
Joined Oct 27, '02
From Barbados
Remember that lower spring have a high spring rate that stock.
The aim is not to bottom out.
But but also increasing te spring rate, it , bounce more. to drease this, the damper or shock must have more damping of increase damping factor. In other word, feel a little harder than stock.
Some spring rate might be a little to hiqh than others.
That is why you should go with well test suspension like Tein HA, Eibach, GroundControl , JIC and so on.
West_Minist
http://www.socob.bb
post Nov 13, 2002 - 8:13 AM
QUOTE (west_minist @ Nov 13 2002, 06:08 AM)
I think that the spring rate in the front is 450 in the front and 350 in the back. Do those numbers sound in line with other springs for the sixth generation Celica?
post Nov 13, 2002 - 9:10 AM
3TST
Joined Sep 27, '02
From UK
FYI
I'm looking into either:
- a set of Koni adjustable's + lower springs (1.5" drop) from my local shop in France running out at around $1250 (plus installation)
- a set of JIC complete "bolt-on" replacement suspension (1.5" drop) running at around $1400 ($1700 for the adjustables) the set of 4 (plus shipping @$200 + installation)
Other than the difference in cost, the Koni's use part of the original KYB shocks for mounting, so I've been told, which means I can't do it myself.
post Nov 13, 2002 - 11:14 AM
west_minist
Joined Oct 27, '02
From Barbados
QUOTE (Coomer @ Nov 13 2002, 06:13 AM)
But also increasing te spring rate, it , bounce more. to drease this, the damper or shock must have more damping of increase damping factor. In other word, feel a little harder than stock.
I really do not know. It souds so, but the 450 to my believe might be for a heavier car like 1500KG or maybe 1400kg and up.
A supra guy mention that same weight to me. Also Tein RA is that weight.
If so, you need a good damper or shock to go with it. The shock that you want seems like the right price , but not quite adequate since you might want a little firmer ride or to combat bottoming out?
Installation + shocks cost=$300+
If I were you, I would go with adjustable shock to accommodate for such high spring weight for your car.
I really do not know much about the weight for the ST and GT usa models.
West_Minist
http://www.socob.bb
post Nov 13, 2002 - 11:39 AM
JWalk1818
Joined Aug 30, '02
From North Carolina
Whats a good set of coilovers to get? Like a resoniable price!
99 Toyota Tacoma
post Nov 13, 2002 - 12:06 PM
west_minist
Joined Oct 27, '02
From Barbados
Groundcontrol, JIC and others.
This my believe.
Why do you want to lower your car?
- For performances and looks or vice versa.
When lowered, what will happen?
- Better ride for stability and performance
- More likely to have ruff ride and some suspension problems?
What should I pay?
- wait and save. Spend cheap and and get ulcers. Let chris tell you. bang, bang, bang! biggrin.gif
- I believe that a good suspension will cost you over $300.
If you want, try a lower spring (Eibach, Intrax, H&R and so on) with a good shock like what is mention about.
Prices depends on where you buy your shocks from.
Try www.google.com to find site that sells shock or suspension kits.
JIC looks like pretty good shock.
Even better, try to find out from celica owner if the ST, GT and GTfour suspension setup is the same. Once so, you have unlimit parts.
I think GT owner have rear disk brakes. Again, we have alot of Japanese GT here usning the 3SFE and 3SGE engines using Rear Disk Brakes. I am not sure on the suspension.
All of this info can then go into the 6gc,net information center for ST, GT, GTfour suspension setup.
West_Minist
http://www.socob.bb
post Nov 13, 2002 - 1:36 PM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE (JWalk1818 @ Nov 13 2002, 09:39 AM)
Go with GC. It will be the best decision that you will make regarding your suspension.
-Bryan-
post Nov 13, 2002 - 1:44 PM
west_minist
Joined Oct 27, '02
From Barbados
GC us a very good low cost suspension.
Suspension is a very subjective topic.
Do some research and make a decision from there.
Buy a good suspension set or setup. it worth the wait.
West_Minist
http://www.socob.bb
post Nov 13, 2002 - 2:47 PM
Mynzeyes
From Franklin/Nashville, TN
yeah, i can atest to the Ground Controls being a little bit better quality, that is what i'm on, i'm dropped all the way (about 2.5") and my car is not too bouncy..it does bottom out on somet things, but you learn how to keep it from doing that, such as slowing down 10mph, hitting the bump in the right spot, etc..i am still on stock struts, if anyone is wondering, and they seem to be holding up, other than a loud THUD when hitting a big bump, the car actually rides very very well.. worth the 400 i spent (free shipping cause my 3day shippiing took 4 days. rolleyes.gif i wouldn't have been mad, but it was the difference from a friday to a monday. rolleyes.gif ) ANYWAY...um...so yeah, my advice is, save up, but if you want somethin now, go w/ the cheapies...but save up or somethin...in the long run it'll be worth it...
-John-
AIM==Mynzeyes
post Nov 13, 2002 - 3:14 PM
west_minist
Joined Oct 27, '02
From Barbados
West_Minist
http://www.socob.bb
post Nov 15, 2002 - 2:03 AM
JWalk1818
Joined Aug 30, '02
From North Carolina
GROUND CONTROLS on Eaby are like 155, is it the real thing?
99 Toyota Tacoma
post Nov 15, 2002 - 5:21 AM
west_minist
Joined Oct 27, '02
From Barbados
QUOTE (JWalk1818 @ Nov 15 2002, 12:03 AM)
Can you send me the link?
Have you check out the part list on 6gc.net for suspension?
Have you check out JIC to?
Either way, I am not sure. Can you search the web for pricing and compare them?
West_Minist
http://www.socob.bb
post Nov 15, 2002 - 12:57 PM
JWalk1818
Joined Aug 30, '02
From North Carolina
Heres the LINK: Dropzone
99 Toyota Tacoma
Lo-Fi Version Time is now: December 4th, 2024 - 5:30 AM
