2 Pages V  < 1 2
> Lowering Woes, And shock questions
post Nov 15, 2002 - 1:08 PM
1_Winged_Angel
From Bay Village, OH
Those are DZ's, not GC's
post Nov 15, 2002 - 1:16 PM
JWalk1818
Joined Aug 30, '02
From North Carolina
OH Crap I misread im sorry my bad! Well are they any good!
99 Toyota Tacoma
post Nov 15, 2002 - 1:32 PM
1_Winged_Angel
The problem with DZ's are you get what you pay for. I hear they make annoying coilover noises, and after a while, the 2 rings that adjust the ride height get weathered, off track, and stuck. There are other things too, but that should be enough.
¤Chrí§¤
post Nov 15, 2002 - 1:34 PM
west_minist
Joined Oct 27, '02
From Barbados
QUOTE (JWalk1818 @ Nov 15 2002, 10:57 AM)
Heres the LINK: Dropzone
They looks pretty good.
Go for them.
But please remember, you should get proper shocks like KYB, Koni and so on to go with the setup, otherwise, you will reget it as you go from 1 - 4".
West_Minist
Hydra EMS Dealer & Tuner
Subaru ECUFlash Tuner
http://www.socob.bb
http://xtremeracingtuning.com
Viciously Tuned, Driven Hard
post Nov 15, 2002 - 1:37 PM
west_minist
Joined Oct 27, '02
From Barbados
To combat noise, some manufactures uses the bumper shock rubber, an extra small "helper" spring and other little technique to combat that problem.
Any coilover with groves will get block with mud and so on. You must keep them clean.
West_Minist
http://www.socob.bb
post Nov 15, 2002 - 2:34 PM
celicaBEst
Joined Oct 12, '02
From Cincinnati, OH
those look really good jason...
i wanna lower my car, just don't have the money to go with the full suspension yet...GC's are the way to go?
-Brian
post Nov 15, 2002 - 3:02 PM
1_Winged_Angel
Gc's are the way to go...even if they are a little more expensive, they are still really cheap for coilovers.
post Nov 16, 2002 - 9:57 PM
CDNSLEEKA
Joined Sep 16, '02
From Yarmouth,N.S Canada
Why not try Eibach springs,SportLines 1.5 drop and either KONI yellows or KYB shocks
post Nov 18, 2002 - 6:17 PM
94celicaguy
Joined Nov 11, '02
i lowered my car this past weekend and it is hell on the road. i know for a fact that it is not the coilovers. i got the ground control springs everyone is talking about on ebay. the ride is so rough on our cars because the shocks. if u get a chance to look at the shock, see how much of the actual shock that you can see. i think i only have about 2 inches that my shock can take a bump with until it bottoms out. this will be the same with any other shock, but the higher performance shocks will have a higher density inside the shock which will take more of the hit than factory.
post Nov 18, 2002 - 8:17 PM
QUOTE (94celicaguy @ Nov 18 2002, 04:17 PM)
That's good to know that it's not just my cheap coilovers and it happens on Ground Controls too. Pretty soon I'll need to buy new struts.
post Nov 19, 2002 - 12:11 AM
ghostdog
From ny to philly
Just wanted to mention that it seems like the springs/coilovers settle over time. In the beginning my ground controls were REALLY bouncy, but now they are much better. I still make a concious effort to drive on good roads and slow down for bumps, but other than that its a pretty good ride. Also re: Koni yellows. I hear only good things about them. But keep in mind they are about 600 for a set, and install will be another 300. Thats almost a grand just for the shocks, but let me reiterate from what I hear they are well worth it.
post Nov 19, 2002 - 12:30 AM
QUOTE (gh0st_d0g @ Nov 18 2002, 10:11 PM)
Do you know if all new shocks are going to cost around that much to install? Is it the same installation procedure for all shocks, or are the Konis harder to install?
post Nov 19, 2002 - 12:42 AM
ghostdog
From ny to philly
QUOTE (Coomer @ Nov 18 2002, 10:30 PM)
KYBs are direct replacements so they pop right in; but they are the exact same shocks as OEM so you probably won't notice too much of an improvement. Koni Yellows, the fronts are direct replacement, they can be self installed, no problem. The back pair are the expensive ones as the strut housing needs to be cut open and then welded shut, a real pain in the ass. I could have mixed the front/back up so don't take my advice word for word, but you get the general idea...
I'll let ya'll know how much it sets me back when I get my Koni Yellows installed in the spring. I'm expecting it to be about 300 though... frown.gif
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 11th, 2024 - 7:20 PM
