> Is a heat shield really nesessary ?
post Aug 9, 2004 - 11:20 AM
are these really nesessary ? I have seen them and they seem to cover 1/3 or 1/2 of the filter ( wouldn't that seem to restrict air flow? ) and how much heat do they really shield. They seem to me to be just for looks.
Let's hear some opinions on this...
post Aug 9, 2004 - 11:37 AM
shid
Joined Jan 8, '04
From LA
The heat shield on the injen intake "blocks" hot air from the engine bay, causing more air to be sucked in from the hole where the stock airbox sucked in cold air.
post Aug 9, 2004 - 2:16 PM
o8poa8o
Joined Jun 11, '04
From Wake Forest, NC
nessisary? NO, Good Idea? YES.
post Dec 17, 2006 - 10:47 PM
Jaws4God
Joined Mar 27, '04
can we get some pictures of the intake shields? i'd like to get one but not sure what route to take.
Thanks!
post Dec 17, 2006 - 10:54 PM
celiracer
Joined Oct 5, '05
From NE
I got one on my injen intake. I think it helps a lot on restricting that hot engine air and giving my of the cold air from the stock intake holes.
post Dec 17, 2006 - 10:55 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
injen seems to know what their doing, so it must be good for something, although i dont use mine
post Dec 17, 2006 - 10:56 PM
post Dec 17, 2006 - 11:03 PM
celiracer
Joined Oct 5, '05
From NE
Haha i didn't even notice the date. But yea i'll get some pictures tomorrow Jaws.
post Dec 17, 2006 - 11:26 PM
6strngs
Joined May 12, '06
From Wilmington, NC
I don't know if it makes any difference, cause the intake piping is hot when the engine is hot regardless of whether or not it has a heatsheild on it.
post Dec 18, 2006 - 12:01 AM
phonex98
Joined Mar 25, '06
Air is a great insulator, which means that it doesn't transfer heat that well. I suspect that air is moving too quickly to absorb much heat from the piping walls, therefore 6strings argument fails. That said, it doesn't prove a heatshield works, as im not sure how well a heat shield block heat form the rest of the bay.... or if the 10 degree difference between engine bay and the rest of the air is noticeable tongue.gif But hey, its not like its hard to make.
----- '94 ST hatch --- Yellow -----
post Dec 18, 2006 - 3:21 AM
manphibian
Joined Oct 13, '06
From UK
Don't get THIS type anyway:
CLICK ME
This post has been edited by manphibian: Dec 18, 2006 - 3:22 AM
post Dec 18, 2006 - 3:51 AM
tin_foil
Joined Jun 7, '05
From Corvallis, OR
QUOTE(manphibian @ Dec 18, 2006 - 3:21 AM) [snapback]511333[/snapback]
CLICK ME
Awesome. I was just about to post a link to our discussion as well. biggrin.gif
QUOTE(phonex98 @ Dec 18, 2006 - 12:01 AM) [snapback]511295[/snapback]
This is a bit off. You're right about air being a good insulator...but only when it's stationary. Circulating air is one of the best ways to transfer heat. I really doubt that nearly any heat shields are a benifit. Maybe some of the best engineered ones are, but I believe that most just end up restricting the air flow. I ran my CRX for a little while with absolutely no air filter. I don't recommend it to at all, cause who knows what crap you'll suck in...maybe a bolt or something, lol. laugh.gif But anyway, reguardless of the rather hot air I was sucking in, my throttle response was absolutely instantaneous and awesome. smile.gif Now I've got an AEM cold air intake on it, and I get a broader power range, but not the heady, roaring, slightly less hp of before. Conclusion: Any filter, short ram, or cold air intake is going to restrict your air flow a little, but it's worth it if it's really sucking in cold air. Low quality heat shield = crap, cause it restricts air flow significantly, and hardly (if any) makes the air colder.
This post has been edited by tin_foil: Dec 18, 2006 - 3:53 AM
post Dec 18, 2006 - 7:14 AM
6strngs
Joined May 12, '06
From Wilmington, NC
alright... I'm gonna take the heatsheild off my intake.
post Dec 18, 2006 - 12:35 PM
Jaws4God
Joined Mar 27, '04
This is a bit off. You're right about air being a good insulator...but only when it's stationary. Circulating air is one of the best ways to transfer heat. I really doubt that nearly any heat shields are a benifit. Maybe some of the best engineered ones are, but I believe that most just end up restricting the air flow. Low quality heat shield = crap, cause it restricts air flow significantly, and hardly (if any) makes the air colder.
I asked my friend the same thing about the intake tube being so hot..
My friends point was that if you don't have a heat shield, you suck in (lets say 80 degree air, then the intake tube heats it up to 90 before it goes into the intake manifold. but if the shield drops the air going into the intake filter to 70 degrees, then it will be 80 when it goes into the intake manifold. (ie the tube adds like 10 degrees))
i'm not sure if this is true or not, but it makes sense..
This post has been edited by Jaws4God: Dec 18, 2006 - 12:36 PM
post Dec 19, 2006 - 2:52 AM
6strngs
Joined May 12, '06
From Wilmington, NC
hopefully the koyo radiator I'm getting will reduce the underhood temperatures so that my intake will actually suck in colder air. though it's probably just wishful thinking...
post Dec 19, 2006 - 3:39 AM
celiracer
Joined Oct 5, '05
From NE
Yea my car runs really cold. My heat bar is like a quarter of the way to the C, Because i have the big air dam in my front bumper. My zyclone hood, and i have a bigger radiator installed so my car runs really really cold.
post Dec 19, 2006 - 6:10 AM
Alex-UKSC
Joined Jul 23, '06
From Chester - UK
I don't use a heat sheild for it's normal purpose as we tested a celica on a RR with & without with no noticable difference. We then run 3 cold air feeds & got some good positive changes, then added the sheild to act more as a air catcher for the cold air ducts!
My Celica Is Now For Sale
post Dec 19, 2006 - 12:31 PM
manphibian
Joined Oct 13, '06
From UK
QUOTE(celiracer @ Dec 19, 2006 - 3:39 AM) [snapback]511608[/snapback]
The operating temperature is supposed to reach halfway on the gauge. If it doesn't it maybe means your thermostat needs replacing kindasad.gif
This post has been edited by manphibian: Dec 19, 2006 - 12:33 PM
post Dec 19, 2006 - 6:39 PM
uberschall
Joined Jul 29, '03
From north of detroit
random crap:
unless your heat shield and intake tube are plastic, they won't won't do much. the themal conductivity of metals (in general) is much higher than plastics.
long story short, any metal object is going to transfer alot of any heat incident on it to anything it touches. that's why most cookware is metal. plastics, rubber, foam, etc are all better insulators.
do you know who i am, mr. worley?
post Dec 21, 2006 - 4:28 PM
shin
Joined Aug 21, '04
From New York City
QUOTE(Batman722 @ Aug 9, 2004 - 4:20 PM) [snapback]167883[/snapback]
OT: muahahaha feel so weird seeing dustin ask questions like this lol. but yea, ya learn alot through these years~
~*MuH NeW RiDe*~
Lo-Fi Version Time is now: November 30th, 2024 - 4:09 PM
