> name that part~, ???
post Aug 14, 2004 - 8:28 PM
DavezXTC
Joined Feb 3, '03
From Pensacola Florida
anyone know what the "hub" part is called, that you have to take the cotter pin out of and put a 20 mm socket on , that entire piece that the brake calipers go on and bolts to the strut? also the cv axle goes into it. the bearings in mine were trashed in a wreck and i need that assembly with the bearings in it (drivers side front) but i need to figure out what it is called before i can order one :D
so far ive thought of, hub assembly?
post Aug 14, 2004 - 8:47 PM
thats what it is a hub assembly pretty much
if you need the bearings just look up "wheel bearing"
i can find you a part number in a bit from advanced auto parts
*edit*
http://www.partsamerica.com/SelectParts.as...earing%2C+Front
that is the link for the part its called a pinion bearing
This post has been edited by playr158: Aug 14, 2004 - 8:49 PM
post Aug 14, 2004 - 8:52 PM
macavely
Joined Nov 4, '02
that the steering knuckel ... i know i had to replace it 2 times..and you have to order every part by its self... if you buy every part new
steering knuckel
wheel hub
seals
rings
caliper
bearing
This post has been edited by macavely: Aug 14, 2004 - 8:55 PM
post Aug 14, 2004 - 8:56 PM
what noise does it make, or vibration or what not......cause my passenger side is making a wierd noise and i can feel it kinda bump like i had a rock in the tire but its not that
post Aug 15, 2004 - 2:42 PM
DavezXTC
Joined Feb 3, '03
it made a noise like the tires were much wider than they are (225/40/17), and looking at the car the camber was way out of wack, that one wheel was pointing inwards and riding on the inside corner of the wheel (ruined a new tire). thanks for the info.
-dave
Lo-Fi Version Time is now: April 21st, 2025 - 11:05 PM
