> HELP!!!
post Mar 1, 2003 - 9:07 AM
edo17982
Joined Dec 21, '02
From Italy
Hi guys!
Yesterday I discovered that during release I leave about 3 feet of blu smoke!!!!!! frown.gif frown.gif frown.gif frown.gif frown.gif frown.gif
Tomorrow I'm going to pull off the head and work it completly.
I'll raise the CR, make a P&P, work the valve's seat....
I'm also thinking to reprofile my camshafts, but I don't have any idea on which cam duration and lift I should use....
My engine is a 7AFE.....suggest me which duration and lift I should use! biggrin.gif
Thanks
Edoardo
post Mar 1, 2003 - 9:40 AM
Guest_Matthew_*
blue smoke??? maybe you are burning oil. check the head gasket.
post Mar 1, 2003 - 9:42 AM
edo17982
Joined Dec 21, '02
From Italy
Yes I know, and maybe it's due to oil filtering the valve guide....but...do you know which values I'd to use for my cams?
Thx
post Mar 1, 2003 - 9:44 AM
Guest_Matthew_*
what engine do you have?
post Mar 1, 2003 - 10:06 AM
edo17982
Joined Dec 21, '02
From Italy
7AFE
post Mar 1, 2003 - 10:13 AM
Guest_Matthew_*
i dunno about that one. i would suggest looking on the web for some sites that sell parts for that engine.
go here http://www.toysport.com/catalog/parts%20by...-97%20parts.htm
look around there some
post Mar 1, 2003 - 11:02 AM
edo17982
Joined Dec 21, '02
From Italy
For my engine I only found one producer of camshafts, Topline that u can find on www.importperformance.com
But I prefer to reprofile my cacms cause I just have 45K miles....
I just like to know if someone can suggest me lift and duration value I can use for intake and exhaust...
post Mar 1, 2003 - 12:39 PM
CelicaLE
Joined Dec 2, '02
From North Carolina
my engine does basically the same thing...mine is burning oil on take off...leaves a nice puff of smoke then it never puffs again really except for the occasional puff on changing gears if i'm running it hard. Instead of putting the money into redoing the engine I just buy a quart of oil around when it gets to the 2,000 marker after an oil change and it usually uses like 1.5 quarts in 3-3500 miles...toyota says this isn't serious oil usage...but heck i do! LOL...but since i have NO money and i can't get enough to redo the engine i'll just keep putting oil in it i guess
post Mar 1, 2003 - 1:00 PM
edo17982
Joined Dec 21, '02
From Italy
It's the same thing I'm doing, but, luckly my best friend is a good mechanic and will work my head, throttle body and intake manifold for no cash!! biggrin.gif biggrin.gif biggrin.gif wink.gif
I'll have to pay just all gaskets, bearings ecc.....
And.....I think that with those mods I'll need a SAFC....
post Mar 2, 2003 - 1:25 AM
FallenHero
Joined Dec 26, '02
From Alabama
I hate you guys. All people around here know how to work on is an old push rod V8. : ( It's ok though, I heard there was a new speed shop around, so there is hope!
post Mar 2, 2003 - 6:40 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
I feel your pain FallenHero, i have to drive an hour just to reach the closest town that has someone that knows how to work on a vehicle that isn't a truck or diesel.
Lo-Fi Version Time is now: November 27th, 2024 - 4:15 PM
