![]() Enthusiast ![]() Joined Jul 27, '03 From Maine Currently Offline Reputation: 0 (0%) ![]() |
i checked everywhere for a post about how to wire fog lights into the firewall and fuses... i was wondering if anyone has added aftermarket fog lights and how they did it... any ideas or suggestions would be great ... thanks
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 14, '03 From Long Island, N.Y. Currently Offline Reputation: 1 (100%) ![]() |
i put the wires right through the steering wheel opening in the firewall. it was the easiest way b/c you don't have to do any drilling. for the fuse, i just used some double sided tape and stuck it on the side wall in the engine bay.
im using pilot fogs. |
![]() Enthusiast ![]() ![]() ![]() Joined Aug 20, '03 From Seattle, Washington Currently Offline Reputation: 0 (0%) ![]() |
hey i did it thur the boot on the passenger side of the car ill take a pic tom. or wed. and show u how i did it.
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '03 From Appleton,WI Currently Offline Reputation: 0 (0%) ![]() |
I led the wires from the battery right thru my driver's side fender and then removed the vent inside the car and led that down to a little plastic removeable rectangle where I cut and put in a switch. It works great because the wires are all hidden. One thing to keep in mind is to find a good ground.
-------------------- ![]() A Jaws4God Creation... |
yea good ground is important
where did u ground it?
There is a ground for the fog lights themself and i fitted them rite underneath the two screws that hold the radiator up. Just slide them right in and tighten the blots. There is a screw inside the vent thing that I slid the ground for the switch. If you want, I could take pictures when I have the time.
if you could that would be great.... thanks for all of your help everyone
Here give this a try look at these pics and see if they help at all
The front ![]() The Inside ![]() THis is the setup ![]() The Ground ![]() Another of setup ![]() This post has been edited by Exile04: Aug 19, 2004 - 8:17 PM |
im getting red x's
figures ill fix them tom.
![]() Enthusiast ![]() ![]() Joined Jan 22, '04 From WA, Australia Currently Offline Reputation: 1 (100%) ![]() |
I was looking at some other instructions to wire fogs, they had a diagram with the fogs inline with a fuse and a relay? what fuse, and what relay would be used?
This post has been edited by ShadowFX: Aug 19, 2004 - 6:50 AM |
All better
Very similar to my setup.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 20, '03 From Annapolis, Md Currently Offline Reputation: 5 (100%) ![]() |
Just curious if any one has wired there fogs up to the head lights? also how.. im thinking of splicing the wires ( a loop and a reote light for the switch) and runnign through the head light fues will this work??? please help quick. Thanks
Enthusiast ![]() ![]() ![]() Joined Jul 7, '04 From charlotte N.C. Currently Offline Reputation: 0 (0%) ![]() |
itll dim out your head lights -------------------- Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph. Next: maybe an elise |
Enthusiast ![]() Joined Mar 17, '04 From Lansing, MI Currently Offline Reputation: 0 (0%) ![]() |
I'm also installing a set of fog lights on my car, and found this picture online of a standard wiring diagram for fogs/driving lights. Now, for the "Ignition Power Source" is it possible to run this wire to the power relay for the parking lights, so that the fogs are only on when the parking lights are? I'm pretty sure this can be done, but does anyone know which wire I would splice it into? I'm having trouble locating the parking lamp relay. Any help from someone would be great! Thanks.
![]() This post has been edited by mike96ST: Sep 28, 2004 - 4:12 PM |
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) ![]() |
splice the fogs into ur blinkers. use the positive that doesnt blink. and ur all finished.
-------------------- ![]() I will return one day. |
Any chance you could tell me where to find it under the instrument panel? Which colors, etc? I'm sure I could figure out where its at, but not distinguish between pos. and neg. Thanks.
if you are asking me you can just unscrew ur turn signal. buy an auto light tester and figure out which wire it is. non green wire is the ground and one of the green wires is the constant pos when the paking lights are on. the other is the blinker.
splice the pos from the fog to the pos of the parking light. then, splice the ground for the fog to the ground of the parking light. this should take you 20 mins three wires two green and the other is the ground. No need for a switch -------------------- ![]() I will return one day. |
Lo-Fi Version | Time is now: February 21st, 2025 - 12:07 PM |
