3 Pages V   1 2 3 >
> Stock Head Unit with Subs?, Can I do it???
post Aug 18, 2004 - 11:47 AM
Sev408
Joined Dec 4, '03
I want to know if i can use the stock head unit with aftermarket subs like JL or something. Im in no way car audio smart so Im not sure what i can and cant do?
thanks for they help
--Scott
user posted image hows it taste motha f*cka
post Aug 18, 2004 - 12:12 PM
Snarfer
Joined Dec 2, '03
From Virginia
I think only if the stock head unit had signal outputs, which I don't know my car had an aftermarket when I bought it. I guess you could make a crossover and wire the subs in with the rear speakers but there wouldn't be enough power to drive them.
post Aug 18, 2004 - 12:46 PM
You'd use a line level converter. It converts the audio signal from your speaker wires to RCA connections. When we wired up Natalie's car, we had to use one because she wanted to use her factory head unit.
post Aug 18, 2004 - 12:49 PM
Sev408
Joined Dec 4, '03
hey coom where would i get this converter at?
maybe you have a link so i know what it looks like.
post Aug 18, 2004 - 12:59 PM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
A line level converter is one option. Another is to use an amplifier with high level inputs. Basically it has the converter built in.
post Aug 18, 2004 - 1:08 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Go to betsbuy or radio shck, they'll have em, But its not going to sound nearly as nice as an aftermarket headunit
post Aug 18, 2004 - 1:24 PM
QUOTE (AudioFreak @ Aug 18, 2004 - 10:59 AM)
post Aug 18, 2004 - 6:33 PM
Sev408
Joined Dec 4, '03
so what amp and sub could i get that would work with the stock headunit with the high level inputs??
post Aug 18, 2004 - 6:35 PM
Lots of amps have high-level inputs...what are you looking for in a system? SQ? SPL? What kind of music do you listen to? What's your budget like?
post Aug 18, 2004 - 7:12 PM
Sev408
Joined Dec 4, '03
uh im more of a rock person with techno everyone once in a while.
coheed and cambria
saves the day
taking back sunday
story of the year
linkin park
that kinda music
and for a sub and amp no more then 500 i guess
possibly cheaper
thanks
scott
post Aug 18, 2004 - 9:16 PM
Pali_playa
Joined Apr 4, '04
From VA, USA
your gonna loose alot of sound quality, but yea all of the above is right
post Aug 18, 2004 - 9:38 PM
shid
Joined Jan 8, '04
From LA
Yeah, its a sound quality issue man.. sound quality issue. High level inputs is never good. If you're looking to spend 500 plus, you can afford a new head unit. A JL sub and an amp to drive it shouldn't be more than 400...
post Aug 18, 2004 - 9:40 PM
Sev408
Joined Dec 4, '03
yeah but its too much work to do put a new head unit in rolleyes.gif also im only putting in a sub how is that going to have bad sound quality. ?????
post Aug 18, 2004 - 10:07 PM
shid
Joined Jan 8, '04
From LA
QUOTE (Sev408 @ Aug 19, 2004 - 2:40 AM)
Are you nuts? Putting a high lever converter, amp, and sub in is a LOT less work than putting a new head unit in with RCA outs.
(No offense meant) but yeah, if it's just the amount of work, new HU = MUCH easier
This post has been edited by shid: Aug 18, 2004 - 10:07 PM
post Aug 18, 2004 - 10:59 PM
QUOTE (shid @ Aug 18, 2004 - 8:07 PM)
But with the new CD player, he still needs to install a sub and amp...
post Aug 18, 2004 - 11:05 PM
Sev408
Joined Dec 4, '03
exactly and thats why i dont understand how teh hell the sub quality could be worse then with ahead unit??
post Aug 18, 2004 - 11:12 PM
QUOTE (Sev408 @ Aug 18, 2004 - 9:05 PM)
Your sound quality won't get any worse when you add a sub to a stock car's audio setup.
But, your entire will most likely not sound near as good with a stock unit as it would with a good aftermarket head unit. wink.gif
post Aug 18, 2004 - 11:38 PM
shid
Joined Jan 8, '04
From LA
QUOTE (Coomer @ Aug 19, 2004 - 4:12 AM)
Actually coom, it will; he's got to split that signal line off of somewhere.
and if he gets a new head unit, he DOESN'T have to split it, and just runs easy peasy RCA wires.
post Aug 18, 2004 - 11:47 PM
Sev408
Joined Dec 4, '03
OMG CAN SOMEONE JUST LINK ME TO AN AMP AND A SUB THAT WILL WORK IN MY CAR ON A STOCK HEADUNIT AND LINK ME TO THE SPLITTER!!!!!!!
post Aug 18, 2004 - 11:48 PM
QUOTE (shid @ Aug 18, 2004 - 9:38 PM)
A good line out converter also is like a line driver...it relies on external power to boost the signal going to the amps, and a good line out converter won't make an audible difference on the speakers that are on the lines that you splice into. wink.gif
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: November 27th, 2024 - 10:47 PM
