3 Pages V  < 1 2 3 >
> Stock Head Unit with Subs?, Can I do it???
post Aug 18, 2004 - 11:50 PM
QUOTE (Sev408 @ Aug 18, 2004 - 9:47 PM)
OMG CAN SOMEONE JUST LINK ME TO AN AMP AND A SUB THAT WILL WORK IN MY CAR ON A STOCK HEADUNIT AND LINK ME TO THE SPLITTER!!!!!!!
I think that a good sub for you may be an Adire Shiva...they're dual 8-ohm voice coil subs and have awesome SQ for $125 from Adire. You'd most likely want a class A/B amp that puts out maximum power at four ohms bridged for the sub. Let me do a bit of research and I'll try to find you a good amp/sub/line-out converter combo. smile.gif
Sev408
Joined Dec 4, '03
thankyou
as stated before i dont know jack about car audio, i can wire it up when i need to but i dont undertand all the terms.
thankyou
scott
This post has been edited by Sev408: Aug 18, 2004 - 11:52 PM
user posted image hows it taste motha f*cka
post Aug 18, 2004 - 11:54 PM
shid
Joined Jan 8, '04
From LA
QUOTE (Coomer @ Aug 19, 2004 - 4:48 AM)
QUOTE (shid @ Aug 18, 2004 - 9:38 PM)
Actually coom, it will; he's got to split that signal line off of somewhere.
and if he gets a new head unit, he DOESN'T have to split it, and just runs easy peasy RCA wires.
A good line out converter also is like a line driver...it relies on external power to boost the signal going to the amps, and a good line out converter won't make an audible difference on the speakers that are on the lines that you splice into. wink.gif
But he still has to split the signal off of someplace, which means opening up panals, etc etc etc - to me, if you're opening up panals and splicing wires, it's just as hard (if not harder) than buying a harness, hooking up a new head unit; and then laying down RCA wires- no cutting/splicing involved.
JL 10W3v2 (midpower 10" woofer, perfect for what you listen too) , you might also want to look into a 10W6, but you'd need a different amp than I'm listing
Alpine 350W amp; make sure your sub is 2 ohms NOTE: This has the speaker level inputs you need!!!!!
Hard to find a 300W amp for under 200 dollars.. it looks like prices on amps and stuff have gone up since 4 months ago.. I wonder why
This post has been edited by shid: Aug 18, 2004 - 11:55 PM
post Aug 19, 2004 - 12:00 AM
Sev408
Joined Dec 4, '03
well i dont want to have a huge hole in my dash thats why i dont want a head unit, and it will probably be stolen if i put one in.
DC aint the safest place for car parts, especially car audio
all i want is a sub to go with my speakers, i happy with my stock upgraded speakers. they sound better then some cars ive been in that have systems.
so i cant run like a 150w amp or anything then?
thanks,
scott
post Aug 19, 2004 - 12:03 AM
shid
Joined Jan 8, '04
From LA
QUOTE (Sev408 @ Aug 19, 2004 - 5:00 AM)
thanks,
scott
You could run a 150W amp if you got a less powerful sub; the W0 still hits pretty hard for the 100-200W range.
post Aug 19, 2004 - 12:05 AM
Sev408
Joined Dec 4, '03
well i want to know the sub is there but i dont want to rattle my license plate? if that helps any.
so what amp could i run on that JL or any sub for that matter it doesnt have to be JL
post Aug 19, 2004 - 12:08 AM
shid
Joined Jan 8, '04
From LA
Just look for a 150W, 200W or 100W amp with speaker (hi level) inputs on it.. then doublecheck some of the other audio threads to make sure the company makes good amps.
Same thing for the subs
A 10W3v2 shouldn't be enough to rattle your plate.. 2 of them together tho.. are smile.gif
post Aug 19, 2004 - 12:11 AM
So you just want some good bass that'll blend in with your stock speakers?
If so, I think running 150 watts or so to a sub will be fine...my 10" Infinity Reference running off a little more than 150 watts from a JBL BP300.1 at 4 ohms was able to hurt my ears in my '88 hatch. wink.gif
And unless you're looking for a nice brand name that everyone recognizes, I wouldn't go for JL stuff, unless you can get a really good deal on it. It's typically overpriced for what it is...the only reason I have a 10W6 is because it was $30. wink.gif
post Aug 19, 2004 - 12:16 AM
Sev408
Joined Dec 4, '03
how about his profile sub?
or this infiniti
will those work?
scott
post Aug 19, 2004 - 12:18 AM
shid
Joined Jan 8, '04
From LA
QUOTE (Coomer @ Aug 19, 2004 - 5:11 AM)
Really? I didn't find that to be the case at all; I find JLs dirt cheap nearly everywhere except good guys- they wanted 200 for a W3; I got mine for 100 each
As for profile; i've heard bad things.. but then people defend them.. and then I hear bad things.
as for Infinity, I haven't heard about the quality of their amps at all.
I was just about to purchase a 4 channel Pheonix Gold Amp, cus I've heard only good things; but suddenly it's 150 dollars more expensive everywhere!! AHH
This post has been edited by shid: Aug 19, 2004 - 12:20 AM
post Aug 19, 2004 - 12:19 AM
It really depends on the type of sub that you get...a sub that has a resistance of 4-ohms would be good for either of those amps...if your sub has a lower resistance, such as 2-ohms, then a mono amp such as JBL's BP150.1 or BP300.1 would probably be better. wink.gif
post Aug 19, 2004 - 12:21 AM
Sev408
Joined Dec 4, '03
so this rockford could work it has 4ohms
and a power range of 50-150
post Aug 19, 2004 - 12:23 AM
QUOTE (shid @ Aug 18, 2004 - 10:18 PM)
I've never actually heard W3s so I can't comment on a comparable sub for around the same price range, but I know that my 10W6 is typically expensive, but I don't find it to be that great of a sub for the price that they usually go for...I'd much rather have a cheaper sub from Image Dynamics. biggrin.gif
post Aug 19, 2004 - 12:26 AM
QUOTE (Sev408 @ Aug 18, 2004 - 10:21 PM)
I'd stay away from Rockford stuff...their subs tend to have pretty poor SQ.
A good budget system for you may be an Image Dynamics ID10v.3 10" sub powered by a JBL BP150.1. It'd be cheap, have awesome SQ, and fair output when you want it to get loud. wink.gif
shid
Joined Jan 8, '04
From LA
QUOTE (Coomer @ Aug 19, 2004 - 5:26 AM)
I've heard good things about IDs, but have yet to actually hear them in person frown.gif
post Aug 19, 2004 - 12:29 AM
Sev408
Joined Dec 4, '03
so where do you suggest i buy the sub and amp from that wont rip me off, i know crutchfield use to jack up there prices.
post Aug 19, 2004 - 12:30 AM
shid
Joined Jan 8, '04
From LA
QUOTE (Sev408 @ Aug 19, 2004 - 5:29 AM)
What??? crutchfield is the cheapest buy you can find usually; I use their prices to talk local dealers down
post Aug 19, 2004 - 12:31 AM
Sev408
Joined Dec 4, '03
damn they changed then, they used to be expensive like 2 years ago.
well i search them then
post Aug 19, 2004 - 12:35 AM
SoundDomain.com is awesome...they'll pricematch CarMedia1.com and IkeSound.com to get you a really low price, which is nearly always lower than Crutchfield. wink.gif And their service is good too...I've ordered a few subs and some headlights from them and I never have problems.
Oh, and TheZeb.com is good too...I've had excellent service with them too.
And Shid, you should listen to some Image Dynamics subs when you get a chance...they're awesome! biggrin.gif I used to have a pair of ID10s and they were the most musical subs that I've owned by far out of the eight that I've owned. smile.gif And the IDMax is excellent as well...not quite as good as the W7, but still a really powerful, really musical sub. smile.gif
Sev408
Joined Dec 4, '03
i checked some sites that people posted and they dont have teh jbl amp or image dynamics sub mad.gif
3 Pages V  < 1 2 3 >
Lo-Fi Version Time is now: November 30th, 2024 - 6:38 PM
