stereo wiring help |
Aug 20, 2004 - 11:00 PM |
Enthusiast Joined Aug 20, '04 From New Zealand Currently Offline Reputation: 0 (0%) |
Hi all, I am trying to install a new stereo and found this "extra" wiring that I have no idea what it is for . It is orange with white stripe and has a japanese label which I obviously cannot read.
Can anyone help?? The "extra" wire thanks KFHOR This post has been edited by KFHOR: Aug 20, 2004 - 11:04 PM |
Aug 21, 2004 - 12:06 AM |
Enthusiast Joined Jan 22, '04 From WA, Australia Currently Offline Reputation: 1 (100%) |
orange/white wire is to (quote from my Pioneer installation manual) to Lighting Switch terminal, which im pretty sure is to dimmer, so you can adjust your head unit brightness with the dimmer switch? if im wrong feel free to tell me. I installed it without this wire and mine works fine. Good to see some kiwis on this site
Aug 21, 2004 - 5:13 AM |
Hey ShadowFX,
Thanks mate. You were right. I found a friend who knew Japanese and got it translated. it says 'night lightning only'. I just fixed the stereo to my car and it works fine. The only weird thing is that there is no ground connection from the car so I am running the stereo without a ground connection. Would this be a problem? KFHOR |
Aug 21, 2004 - 8:52 AM |
Enthusiast Joined Apr 4, '04 From VA, USA Currently Offline Reputation: 0 (0%) |
if there is no ground that means that the radio uses the antenna as ground, so ur okay there, but u might not want to connect the illumination wire (orange or orange/white) b/c it can short your system out. basically that wire is only used on really old cars.
Aug 21, 2004 - 10:28 AM |
glad to help.. ooo wow i helped someone. now i feel all fuzzy and tingly inside
Lo-Fi Version | Time is now: December 3rd, 2024 - 4:35 PM |
