2 Pages V  < 1 2
> Front KYB inserts, anybody have them installed?
post Aug 26, 2004 - 3:23 PM
mr_dude
Joined Feb 16, '04
From San Diego
Those drill-looking things that they used to put on and remove wheels (autoshops, nascar, etc). Make a cool whirring sound.
Air powered, provide a series of short impacts to put on or remove a nut. Saved my ass from having to cut and reorder a strut insert... don't ask.
post Aug 26, 2004 - 3:28 PM
celicaboston1983
Joined Mar 20, '04
yea those are cool and saves time
post Aug 26, 2004 - 3:33 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
Air tools. You do need them for this project. Its almost impossible to get those 2 large bolts on the steering knuckle off without an impact wrench. Just a little FYI for you Do-It-Yourself'ers. In fact, dont get scared if you dont have this tool. If you doing this type of project, I'm sure you'll need to just an air tool again. Its not a bad idea to go purchase one from a tool store (not walmart.) smile.gif Again good luck guys.
post Aug 26, 2004 - 5:17 PM
mr_dude
Joined Feb 16, '04
From San Diego
Nah, I just stuck the wrench into the ground and eased the car off the jacks. The weight of it turned the wrench and loosened the bolt.
Just kidding, but I did get it off with the help of a friend and ratchet extension.
post Aug 28, 2004 - 2:36 PM
98celica3
Joined Aug 30, '02
From North Carolina
QUOTE (macavely @ Aug 24, 2004 - 12:50 PM)
here are some pics.. oncer you take the sturt off and remover the spring, undo this nut
oncer you have it off
pull out the old insert and replace it with the new one.. and if you have the original ones still in what out for the oil..
are those the stock front struts? mine don't look like that. i had to beat that nut off when i put my coil-overs on so the sleeve would fit onto the strut.
adam
MISS THE CELI, BUT...
post Aug 31, 2004 - 7:11 AM
macavely
Joined Nov 4, '02
no they are not the OEM ones they are KYB"S ... the stock ones are black and a lot tinner then that..
post Sep 3, 2004 - 10:49 AM
turboinduction
Joined Feb 25, '04
From Wisconsin
QUOTE (macavely @ Aug 31, 2004 - 7:11 AM)
just to clarify:
that is the stock front strut assembly
however, that is a new KYB strut insert
post Sep 3, 2004 - 5:16 PM
TTE
Joined May 19, '03
From NJ
I see that mine front struts were different, they didnt have that nut only a cap . I think Toyota changed struts on later models.
post Sep 13, 2004 - 8:20 PM
coustoe
Joined Sep 18, '02
From Northern, Virginia
guys, do the kybs lower the car any from stock?
post Sep 26, 2004 - 4:45 PM
racingmcfly
Joined Jun 14, '04
From Wimborne Dorset England
Anyone know or has removed the standard kyb cartridge from the Superstrut Setup, Ive heard it cant be done but it looks very similar to the pics here!
post Sep 29, 2004 - 6:19 AM
97Celica
Joined Nov 27, '02
From Derry,NH USA
Why type of performance difference do you get from swapping the stock Mcpherson setup to KYB? Smooth ride? Better handling? etc...LET ME KNOW PLEASE! I have to replace the struts in my 92..and if I like them,I will do it in my 97.
2 Pages V  < 1 2
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 25th, 2024 - 8:37 AM
