3SGTE/StandAlone |
3SGTE/StandAlone |
Aug 23, 2004 - 7:56 PM |
JUst wanted to know from you guys that have done the swap or are over seas, that are using a Stand Alone ECM along wiht there 3SGTE... and how is performance campared to the stock ECM?
Aug 23, 2004 - 8:06 PM |
if I had the money i'd definately do it, best thing to do for ur car for more power.
Aug 23, 2004 - 8:11 PM |
Now I'm kind of curious...if a person were doing a 3S-GTE swap, would wiring be any easier using a standalone EMS compared to using the 3S-GTE's stock ECU? I know there would be extra work in the form of tuning, but I'm not sure if wiring would be much different, and harder or easier.
Aug 23, 2004 - 8:40 PM |
well i think it might be simpler... but thats jut me... thats why i'm asking.. cause after seeing all the people with swaps on this site.. i'm kinda leaning back towars its... and if i do it... i want go get a stand alone no if ands or buts about it.. -------------------- |
Aug 23, 2004 - 9:40 PM |
i would say that it would be harder.
on the 3sgte ecu...you baiscally have to rewire one plug that goes to it. with the standalone, you would have to rewire all of them, and the get everything tuned to have it running right. check www.mr2oc.com for more info on standalones. there are a few guys on there that have them. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 24, 2004 - 12:11 AM |
Enthusiast Joined Jul 24, '04 From Va Currently Offline Reputation: 0 (0%) |
Standalone will be worth every penny you put into it. If your good with electronics try Megasquirt. If you need to buy a setup look at Tec 3, Augtronic, SDS ect ect.
Lo-Fi Version | Time is now: November 25th, 2024 - 2:19 PM |
