> Rotor Price front and rear?, know where to get these?
post Aug 25, 2004 - 11:32 AM
coustoe
Joined Sep 18, '02
From Northern, Virginia
I've been looking all over the net for just plain rotors, not drilled or slotted. but the ones I find are even more expensive then the drilled or slotted rotors like $50 for 1 rotor!!!
anyone know where I can get these cheap?
Thanks
post Aug 25, 2004 - 11:55 AM
LatinKraze
Joined Oct 22, '03
That's about right for the OEM rotors. I bought mine on line for $86 for 2. Ill try and find a site for you.
post Aug 25, 2004 - 12:46 PM
coustoe
Joined Sep 18, '02
ahhh this sucks, might as well get cross drilled slotted, even though they suck, be cheaper.
post Aug 25, 2004 - 7:19 PM
DamDirtyApes
Joined Apr 22, '04
From Rhode Island
arent the cross drilled and slotted ones supposed to be b etter for stoping?
post Aug 25, 2004 - 7:46 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
you wont really see the differance in performance with the drilled/slotted, they are mainly for competition. if you go to car quest, the front rotors for a gt are $25, autozone wants 50 a piece, or 98 a piece for ones with the warranty.
with the drilled/slotted, you will need to buy ceramic pads, $39 at autozone(for the front pair)
be sure to replace the pads and rotors at the same time
post Aug 25, 2004 - 7:53 PM
VietCelicaGt
Joined Aug 13, '03
cross drilled and slotted <<<bad or good??
post Aug 25, 2004 - 7:59 PM
redtcel
Joined May 19, '04
From The Coast, New Hampshire
bought all four rotors, front and back for $89 total. try napa auto parts, they have everything
post Aug 25, 2004 - 10:37 PM
coustoe
Joined Sep 18, '02
nice ill check out napa
post Aug 29, 2004 - 10:51 AM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
you can also check out nopi
post Aug 29, 2004 - 12:04 PM
shid
Joined Jan 8, '04
From LA
cross drilled/slotted = good; but you have to wear them in for 100 miles before they get better; too many holes or slots = bad
post Aug 29, 2004 - 12:07 PM
hyp3rk1d
Joined Sep 22, '03
Napa.. I paid like 37.50 for 2 front ones.. I was amazed.. Seeing as be4 hand i went to Advance Auto Parts and paid 120 for 2 front rotors.. I went right back and returned them and went to NAPA.. And they work great biggrin.gif
post Sep 2, 2004 - 12:00 PM
bonzaisushi
Joined Oct 3, '02
From bonzaisushi@hotmail.com
about 1 month ago i got 2 front and 2 rear brembo cross drilled zinc plated and chamferd rotors with axiss metal master brake pads for about 350 shipped havent had a problem with them yet other than squeaky brakes...... frown.gif ........ they painted the hub part to so it doesnt get all rusty and nasty like....took about 1 hour to change all 4 with pads....ebay
Lo-Fi Version Time is now: November 25th, 2024 - 2:40 PM
