Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) ![]() |
I am gettin some kind of clunking noise from my passanger side rear brake assembly. it comes and goes but if I push down the break pedal I get a quick clunking noise. It doesn't seem to make a difference if I am moving or not. I am also gettin a little bit of break release noise.
I have these parts installed: russel stainless steel brake lines Brembo cross/slotted rotors CF composit brake pads I have checked out the brakes now 3 times and I can't seem to find anything wrong with it. I have removed the calipar and inspected EVERYTHING and cleaned it all up and reapplied the silicone brake grease. I have aslo checked the swaybar so I know that not it either. So if neone has ne ideas of what I might have wrong - PLEASE LET ME KNOW thanks NEVERSTOP -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
Enthusiast ![]() ![]() ![]() Joined Sep 18, '02 From Northern, Virginia Currently Offline Reputation: 0 (0%) ![]() |
maybe its your sway bars
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Hecho en la Republica Dominicana/Living in NJ Currently Offline Reputation: 0 (0%) ![]() |
your clipers might be sticking... if they are then your going to have to take it apart sand it down and lube it up... (get your mind out of the gutter you sick basterds.) .. iyou might also want to check for and air pocket in your lines... if i think of anything eles ii'll let you know
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 13, '03 From California Currently Offline Reputation: 2 (100%) ![]() |
did you make sure that the brake brackets are in place...the pad might be sliding around
-------------------- 2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3 gone but not forgotten 2008 Space Grey BMW Z4 ///M 2009 Black Honda Civic LX Coupe 2006 Magnetic Black Nissan 350Z 2007 Crimson Red BMW 335i Coupe |
ooops double sorry
This post has been edited by fastgt: Aug 25, 2004 - 4:37 PM -------------------- 2011 Spice Orange Mini Cooper
Naw checked those
did that it seemed to help some but not much.. might of just been my imagination though ![]()
that was the 1st thing I thought and checked it and there okay Had a friend check it out yesterday.. he had a similar prob in his 99 SI, after he installed his lowering springs, he said his prob was that the 3 upper strut bolts (strut tower) had come loose. I checked these by hand yesterday and they seemed like they might of worked themselves a little loose but wasn't able to tighten them down with nething... will try this weekend and see.. if that the prob I'll let you guys know ![]() -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 25, '04 From Wisconsin Currently Offline Reputation: 0 (0%) ![]() |
did you check the e-brake and make sure thats not sticking?
Oh, how did you get Brembos on the back????? |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) ![]() |
i have that same prob, so let me know how you fix it!
Its not the ebrake.. I checked that a while back. as for the brembos I got them off ebay from mastergrade. The authentic stamped bremebo.. and they just slid right on ![]()
If I figure it out I will.. check the strut tower bolts and there fine.. gonna disassemble the calipar agian this weekend and check everything out, It wasnt making the noise yesterday so who knows ![]() -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
![]() Enthusiast ![]() Joined Aug 30, '02 From Austin Texas Currently Offline Reputation: 0 (0%) ![]() |
i have the same problem..except mine are oem brakes and only do it on random.
well I havent heard the sound in almost a week now.. so I dont know
Enthusiast ![]() Joined May 25, '03 From Ft. Wayne, IN Currently Offline Reputation: 0 (0%) ![]() |
I have this problem too. I did the conversion, so i just figured I screwed something up. I hope someone finds out what it is.
tommorrow I will be messing around with my brake system so I will try a few things and see if I can improve nething.. the sound has come back now so I gotta get it figured out.. have narrowed it down to the capliars
Enthusiast ![]() Joined May 2, '03 Currently Offline Reputation: 0 (0%) ![]() |
did u check your bearings ? it could be bent
yea kinda starting to lean in that direction.. I checked the calaipars out yesterday and everything is tight.. do have alot of play on the the top half of it and am thinking my guide pins my be going bad. Ill replace both and see if that helps... I hate matiance stuff... would rather spend the cash on performace stuff ![]() -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) ![]() |
hey never can you put some pics up of your new bakes? -------------------- yea your 3sgte is cool but ill stick to my 7agte
Lo-Fi Version | Time is now: February 19th, 2025 - 5:31 AM |
