> ENGINE ADDITIVES, please sticky this if you feel its worth
post Aug 27, 2004 - 6:26 PM
OIL ADDS:
Bar's leaks-engine oil stop leak-reduces oil leaks in engine
Bar's leaks- SMOKE away- reduces oil leaks into combustion chamber (reduces exhaust smoke)
Gunk Stop smokin- stops oil leaks into combustion chamber (reduces exhaust smoke)
STP smoke treatment- reduces exhaust smoke
CD-2 oil treatment- reduces oil leaks in engine, helps the lubricating effects of the oil
CD-2 Heavy duty engine oil stop leak- for bigger oil consumption problems
CD-2 oil detergent- cleans the piston rings, valves, and lifters
Gunk vavle medic- frees/cleans sticky vavles and reduces noise
Gunk bearing seal- help condition and protect bearings if you experience engine bearing problems
OIL stabilizer Heavy Duty- stabilizes the oil so it will take higher temp. and won't break down as easily
Lucas HD oil stabilizer- strengthens oil integrity, raise the oil temp. withstandings. extra lubrication
Restore 4- engine lubricant, helps restore lost compression, and fill tiny scrathes in cylinder wall
grease lightning engine treatment- conditions engine, same as restor4^
STP oil treatment- helps lubricating powers of oil, and viscosity
STP 4 cyl oil treatment- conditions oil, specifically designed for 4 cylinder cars
Gunk 5 min. motor flush- ENTIRE engine detergent, cleans out carbon particles that are stuck, lubricates engine, reconditions cylinder walls
Slick 50 engine treatment- same as above^
Goldeagle oil system flush- cleans out oil system, carbon deposits
Marvel mystery oil Gas and oil treatment- cleans oil and gas!?
X-1r engine treatment
Seafoam motor treatment
OUTLAW compact oil treatment
LUCAS synthetic oil stabilizer
Z-max micro-lube power system treatment
Greased lightning "stop-it" engine stop leak
Pro-blend xtreme sport engine oil treatment "oil coolant" reduces oil temp up to 52 degrees F
thats all for oil wise/engine.....later on comes FUEL system and cooling
Lo-Fi Version Time is now: January 17th, 2025 - 6:30 PM
