> AWD conversion, How complicated
post Aug 28, 2004 - 4:17 PM
lantz2121
Joined Jun 27, '04
From ohio
Has anyone preformed an AWD conversion? I am debating on FWD MR2 tranny or AWD? Does the rear subframe bolt right up to a factory st frame? Give me some feedback from those who have preformed this swap. thanks lance confused.gif
post Aug 28, 2004 - 4:25 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (lantz2121 @ Aug 28, 2004 - 9:17 PM)
there is no subframe. The celica is a unibody. You literally have to cut and paste (grind and weld) mounts for the rear-end. Anyways, try doing a search. I've responded in detail about this a bunch of times...
post Aug 28, 2004 - 4:35 PM
Anub1s
Joined Nov 27, '03
post Aug 28, 2004 - 5:08 PM
DamDirtyApes
Joined Apr 22, '04
From Rhode Island
you would have to do so much to your car, it would cost so much money. not worth it from what iv heard. the gt-4 has different welds that provide greater strength. you would have to redo the whole frame basically. in other words, its not going to happen unless you got mucho dinero
post Aug 28, 2004 - 6:26 PM
lantz2121
Joined Jun 27, '04
From ohio
Okay I've searched and searched. I didn't know that converting to awd has been such an issue. I can't belive we have guys that have done complete motor swaps wiring, etc and no one has sucessfuly done and AWD conversion. I am going to try it anyway. Even with the lack of info. In one of the posts neverstop said he "did" one. what happened after he hit 120? keep you posted. Much thanks for the posts from some. Lantz
post Aug 28, 2004 - 7:10 PM
shid
Joined Jan 8, '04
From LA
QUOTE (lantz2121 @ Aug 28, 2004 - 11:26 PM)
(IMHO)
This post has been edited by shid: Aug 28, 2004 - 7:11 PM
post Aug 28, 2004 - 7:19 PM
his BS fell apart
(IMHO)
BWAHAHAHAHAHAHAHA hehehe
dude, your in for ALOT more work than you think...hope you or someone you know just happens to be a MASTER welder, as well as an engineer...and have the practiacal knowlage to put it all together.. rolleyes.gif
Lo-Fi Version Time is now: January 16th, 2025 - 2:58 PM
