> light grey/white smoke, Got some injection troubles...
post Aug 28, 2004 - 7:09 PM
Eddo456
Joined Jun 8, '03
From Tampa, FL
Hey you guys, i was wondering if anyone could offer some help with my car. I am getting some light grey smoke and am wondering what to do. I already used some valvoline injector cleaner, to no avail. Should i look into continuing the cleansing or just replace my injectors, if so about how much would a set of four cost? Thanks for you help.
-Eddie
post Aug 28, 2004 - 9:43 PM
Rjb23
Joined Feb 8, '04
From KY
White smoke means a coolent leak probably a head gasket.
post Aug 28, 2004 - 10:31 PM
5sfeTurbo
Joined Apr 14, '03
YEP!!! Just had mine pop on me $1200 bucks. Do not drive it unless its to a shop that will cause the damage to eat your wallet.
post Aug 28, 2004 - 10:47 PM
ShadowFX
Joined Jan 22, '04
From WA, Australia
yup, our 4wd just had head gasket leak.
post Aug 29, 2004 - 4:56 PM
Rjb23
Joined Feb 8, '04
From KY
This is how you find out. Warm your car up until the fan kicks in, feel the top hose of the radiator to the engine and make sure it is hard/pressurized. Then let your car cool down and remove your spark plugs, crank the engine while the plugs are out and if coolant comes out of the holes then you have a head gasket leak.
If the smoke is not heavy, and you just get it at first on start up, you are probably fine and it means nothing.
post Aug 29, 2004 - 8:59 PM
Eddo456
Joined Jun 8, '03
From Tampa, FL
It isn't heavy, and just on start up, just something that has bothered me a bit. If it is no problem then i wont' worry about it, thanks for the help.
-Eddie
Lo-Fi Version Time is now: April 23rd, 2025 - 9:22 PM
