> I Think its Time to Swap., 3SGTE owners, input please
post Sep 1, 2004 - 4:20 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
So lately I've been thinking seriously about what direction to go performance-wise after kicking around ideas for quite some time now. This led me to a conclusion of what i want out of it-
1.) MORE POWER dammit!
2.) Reliability, since I drive back and forth to college every day.
3.) Upgradability, which the 3SGTE has in spades.
This led me to thinking about HOW I would do it. I'm not exactly in the position to do it myself, since I dont have nearly the mechanical skill that I wish I had to swap in an engine. And sure, I know theres guys in my area (Lagos, DG, Supersprynt) who know how, but I wouldnt expect you guys to undertake anything like that or walk me through it.
However, I read of a shop in Sport Compact Car that swapped a full WRX powertrain into an Impreza 2.5RS in south Jersey. So, I contacted them to see what they thought about performing the swap on a 6th generation Celica.
I said-
To all at Rallispec,
> I'm located in Northwest New Jersey, and read about your company in Sport
> Compact Car in an article with a swapped Impreza 2.5RS.  I own a 6th
> generation 1994 Toyota Celica GT 5spd, which can be transplanted with the
> 3SGTE engine and MR2 turbo manual transmission as opposed to the very
> conservative 5SFE that comes in it from the factory, and like many other
> Celica owners I am currently interested in having this swap performed.  I
> recently saw on your site that you had built up a ST165 for rallying, so I
> assume that you have some knowledge in working with the 3SGTE.
> I would like to ask if Rallispec was capable or willing to perform a 3SGTE
> swap into a ST204 Celica platform, or if performing such a swap would be
in
> your interests.  There is a large demand among Celica owners of every
> generation to swap in a 3SGTE in place of their less potent stock engines,
> and several shops in California (EL Prototypes, etc.) and Florida (Such as
> XAT Racing, JAMASCO) currently offer this swap due to popular demand and
> with great sucess.  Unfortunately, few (if any) shops in the Northeast
offer
> any such services, and the Celica community which I'm part of could use a
> good shop to help them with their performance needs.
> If you could let me know your thoughts on performing this engine swap I
> would appreciate it.  I am also an active member on several Celica sites
> such as 6gc.net and Celica.net, and could reccomend your shop to other
> members if this was in your interest.  I would appreciate any feedback you
> may have.  Thanks.
> -Corey
Then they responded-
Corey,
Corey,
I appreciate your email and it is a very interesting proposition.  However,
you should know that although we have extensive experience working with the
3SGTE in the ST165 rallycar we built, we do not have much experience with
either the 6th generation chassis nor the 5SFE.  So I really do not have any
idea what type of potential issues or complexities might arise during the
swap.  While I am confident we could overcome any issues, I would really
have to make a random guess as to the time and the cost in doing such a
swap.
Naturally the questions that you would need to answer before we could even
think about getting started would be:
1.  Will you be supplying the necessary parts for the swap or will we?
2.  What is to be done with regards to engine management?  Will we be making
use of the factory ECU for the 3SGTE?  Will a engine wiring harness be
supplied with the engine?
3.  What about exhaust and intercooler systems?  Some custom work will
likely be needed in these areas.
4.  What is your time frame for wanting to get this done?  How long can you
be without your car?
Let us know and we can start looking at working up a rough estimate and
trying to fit such a job into our schedule.  Thanks.
Regards,
Dave
RalliSpec
So I'm sure doing this would be a first for them, but I need you guys that have done the swap to help me out and list what kind of issues you'll run across, like the ignitor issue I've heard about and also more information on using the MR2 Turbo transmission with hybrid axles. I want to give them a good idea of what it entails if I decide to go to them, however i dont know enough about it to tell them. So, any help would be appreciated. wink.gif Thanks in advance,
-Corey
post Sep 1, 2004 - 6:35 PM
its cool to see that there is a shop lilke theirs that seems fairly inteligent and somewhat honest. just hope they are cheap too.....where are they located and do u have a website or contact info for them?
you mentioned that me, sprint and DG, have enought skill to do these swaps, but what i think you are forgetting is that none of us knew a thing about our cars before doing the swap. you lean while doing it. so if you are at least hard working, motivated, and good with your hands, you too can do a swap!
1st thing you should do is make sure you buy a clip and not try to get a deal on just the engine. with the clip, you will have the ignitor, coil, resistor pack, ecu, harness, and all the little stuff that come in handy.
2nd thing, is to make sure this shop can do harness work. basically, you have to take the 3sgte harness make it work with the 6th gen. this means that you have to fully rewire the main engine bay fuse box, rewire the 3rd ecu plug, rewire 3 "interrior" plugs that sit right above the ecu, and add in your own fuel pump relay.
installing the 3sgte is basically the same as installing a 5sfe. the only thing to rememeber, is that you might want to grind down your passengers side motor mount a little, cause it touches the timing belt cover.
if you have a 5sfe tranny thats in good condition, you can shure as hell use that. and mr2 trubo tranny is the best solution, but its hard to find and cost more money. i went with a 5s tranny, because i would rather have one i know is in good shape, then to buy a junk yard one and pray its good.
This post has been edited by lagos: Sep 1, 2004 - 6:41 PM
post Sep 1, 2004 - 7:21 PM
Silver94CelicaOw...
Joined Oct 13, '02
Thanks for the info Lagos. I would consider undertaking it myself if I knew a little more going into it and had good tools to work with, but i just want the assurance that its all done right the first time and that it will be reliable. I drive back and forth to college everyday, so its important that it serve the role of daily driver very well. I wish I could, but I just dont think I want to count on that.
I planned on getting a MR2 turbo rear clip to do the swap because that would include the tranny along with it. The shop asked about all the important things in their response, and im confident that they know what they're doing. They mainly focus on Subarus, but have built up a ST165 Celica Rally Car, so they know the 3SGTE.
The shop is called RalliSpec, located in Hainesport, NJ which is near Mount Holly/Cherry Hill. So I figure thats not too bad of a distance to go and get it done.
Their site is www.RalliSpec.com so go take a look. They do all kinds of fun stuff to cars. smile.gif
post Sep 1, 2004 - 7:33 PM
well it sounds like a good plan.
the only thing that has me worried is the mr2 clip you plan to get. while in theory its a great idea cause you get the trans and engine...the shop will proabaly had a harder time with it then they would with an st185 clip. also, no one here knows how to convert and mr2 harness to work with the 6th gen, so that would be all up to your shop to figure out.
post Sep 1, 2004 - 7:40 PM
looks like this place is about 40min away from me .... nice find!
i may contact them about doing a 3in mandrel bent exhaust for me.
post Sep 1, 2004 - 8:11 PM
Silver94CelicaOw...
Joined Oct 13, '02
No problem. wink.gif Maybe I should look into just getting an MR2 Turbo transmission in addition to a ST185 clip....I just dont like the sound of bolting a 200+ horsepower engine to a 10 year old transmission that already has a not-so-smooth shift to it, along with a hesitant synchro going in and out of 4th gear.
Hmm, thats a tough choice though. I'm not sure how much extra work the MR2 tranny would take, but maybe just an upgrade to a newer transmission would be wiser and more cost-effective.
I think that you should look into the mandrel bent exhaust setup, and let them have a peek at your engine while youre there. wink.gif
post Sep 1, 2004 - 8:51 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
speaking about the transmision.. why do people use the gt tranny if its not going to really hold under the power.?? also what will hold under that power, just the mr-2 tranny??
post Sep 1, 2004 - 9:08 PM
QUOTE (Digndoug @ Sep 1, 2004 - 6:51 PM)
the truth is that there is no real proof that the gt tranny can or cant hold the power. it all depends on condition of the tranny, driving style, etc...
i believe mine will hold up. if i didnt, would have swaped to a mr2 one. oly time will tell tho.
as far as whats best.... hands down the mr2 trans. some people will try to tell you u can use a solara tranny too, but i talked to a few people that wish the never uese the solara one.
post Sep 1, 2004 - 9:26 PM
sinner96ST
Joined May 15, '03
From Aurora IL
save up money
go here and get this and tell us how it works out. i'm curious.
post Sep 1, 2004 - 9:35 PM
fastgt
Joined Feb 13, '03
From California
sinner i couldnt pay attention to ure post....too focused on your icon
2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3
gone but not forgotten
2008 Space Grey BMW Z4 ///M
post Sep 1, 2004 - 9:47 PM
spunky393
Joined Apr 22, '04
From illinois
so what do you do sinner, send your car there? i don't get it.
post Sep 1, 2004 - 9:49 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
QUOTE (sinner96ST @ Sep 2, 2004 - 2:26 AM)
save up money
hummm, they changed there prices... it used to be like 5500 for the 3rd swap..
post Sep 1, 2004 - 10:48 PM
sinner96ST
Joined May 15, '03
From Aurora IL
i dunno, you could probably ship your car out there to have it done, or just go there yourself.
those prices aren't bad for what they offer.
post Sep 2, 2004 - 10:34 AM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
yeah they raised their prices by 600 for 2nd gen and @1k for the 3rd gen
post Sep 2, 2004 - 11:56 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
but it now specifically says what they plan to do in regards to the tranny...
post Sep 2, 2004 - 12:49 PM
Anub1s
Joined Nov 27, '03
I wish I had the time to drive down to Tampa now frown.gif I want a swap so bad, just don't have the time to do it myself otherwise I would.
Lo-Fi Version Time is now: January 15th, 2025 - 12:56 PM
