> FS: SOME PARTS
post Sep 1, 2004 - 10:40 PM
CelicaFanatic
Joined Apr 22, '04
From California
Once again. i got 3 6th gen celicas, all ST's, 2 hatches 1 coupe, and 1 manual that im parting. i dont have any front end lights or aftermarket parts.
post Sep 1, 2004 - 10:44 PM
3FingersCelica
Joined Aug 21, '03
From Endicott NY
what years do you have cuz I need a 96-97 EGR Valve.
post Sep 2, 2004 - 1:31 AM
CelicaFanatic
Joined Apr 22, '04
From California
post Sep 2, 2004 - 1:34 AM
Akimbo
Joined Jun 30, '03
From O-town, FL
Leather seats?
- Ryan
aim: rkgreen04
post Sep 2, 2004 - 1:57 AM
CelicaFanatic
Joined Apr 22, '04
From California
seats arent leather and are ripped.
post Sep 2, 2004 - 12:04 PM
gtcelica94
Joined Apr 4, '04
shift knob and boot
post Sep 2, 2004 - 1:08 PM
JSPEC25
Joined May 8, '04
From CENTRAL IL
I need the wheel hub for the drivers side front, (the assembly that houses the wheel bearing. let me know how much and a pic would be needed.
post Sep 2, 2004 - 1:13 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
i need all parts for manual that are non-ST parts
like the pedal and such...
-Shifter
-Shift Cables
-Slave cylinder
-Clutch metal fluid lines
-Rubber clutch line
-Flywheel bolts
-Pressure plate bolts
-Clutch pedal assembly
-Manual brake pedal
-Brake fluid for clutch
-Manual Transmission Drivers Side Mount
-Starter Relay for Manual
-2 bolts for Trans- 12 by 1.25 (1 is 65mm other is 75mm)
-Gear Greace
i think this sums it up???
This post has been edited by Consynx: Sep 2, 2004 - 1:18 PM
post Sep 2, 2004 - 1:23 PM
FallenHero
Joined Dec 26, '02
From Alabama
how much for a front bumper?
post Sep 2, 2004 - 1:46 PM
Rjb23
Joined Feb 8, '04
From KY
QUOTE (Consynx @ Sep 2, 2004 - 6:13 PM)
-Gear Greace
You also need the slave cylinder rod, and rubber peice. The reverse light plug that goes to the tranny, the manual ECU, and the clutch master cylinder if you don't already have it.
post Sep 2, 2004 - 3:17 PM
Makaveddie
Joined Dec 5, '02
From Sacramento, CA
once again... any tan interiors? if so I need the drivers side sun visor and passenger side door panel. please email me. ed.
post Sep 2, 2004 - 3:48 PM
Consynx
Joined Dec 25, '02
woops, thx for catching that.
but i can't use his ECU because they're ST...right?
post Sep 3, 2004 - 6:00 AM
Rjb23
Joined Feb 8, '04
From KY
QUOTE (Consynx @ Sep 2, 2004 - 8:48 PM)
Right but you also won't be able to use the pressure plate bolts, the tranny bolts,
probably not the shifter or the cables, Flywheel bolts, Manual Transmission Drivers Side Mount, and probably not the Starter Relay for Manual.
About the only things that are probably the same is the shifter, the clutch pedal assembly and the tubing. Not for sure though you probably will want to check.
post Sep 3, 2004 - 4:52 PM
frosty
Joined Sep 1, '04
From Alabama
I need the radiator support for my 95, I'm sure you have one there?
CLOSED on 25 acres!
-shop coming soon....
post Sep 3, 2004 - 6:36 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
rear view mirror?
post Sep 6, 2004 - 2:27 PM
exxtractor
Joined Mar 31, '03
From BC
What color are the backseats and how's the condition? Just interested in the fabric, not the seat themselves.
Lo-Fi Version Time is now: February 18th, 2025 - 4:12 PM
