Vortec FMU, which to get for 5sfte project |
Sep 2, 2004 - 1:21 AM |
Enthusiast Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) |
well originally was goin to go with a 8:1 FMU but have a chance to get the 12:1 for pretty cheap.. do you guys think this would be too much for the 5sfte?
Thanks -------------------- 99 project version 3.0.. hello SEMA 2010 =) |
Sep 2, 2004 - 1:25 AM |
Enthusiast Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
get RR FPR, it will be better, you will be able to adjust the pressure like you want.
12:1 is a bit too much Matt. I sugest going with 8:1 -------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Sep 2, 2004 - 1:32 AM |
okay thats kinda what I though.. what about a 4:1?
Sep 2, 2004 - 9:22 AM |
Enthusiast Joined Feb 25, '04 From Wisconsin Currently Offline Reputation: 0 (0%) |
8.5:1 would be perfect 4 is way to low - you wont be able to move the car until the turbo spools and 12... well... cut a hole in your hood so you dont damage it when the block goes up in the air. |
Sep 2, 2004 - 10:11 AM |
Enthusiast Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
12:1 will make you run stupid rich
hold out for an 8:1 -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Sep 2, 2004 - 12:26 PM |
well think I might try the 4:1 at first just cuz the price I can get that one for.. and if I think its runnin too lean i'll swith to a 8:1 diafram (sp?). I'm running a warblo supra fuel pump and the fuel lines are new also so think I should be alright.. if not I'll know right away and swap it out to 8:1
Sep 2, 2004 - 1:32 PM |
um i think its better to start with a rich running setup then leaning it out. more than likely 4:1 will run really lean. if you want one right away, get the deal on the 12:1 and then switch to the 8:1 diaphram. its safer. -------------------- 1994 Celica GT4 WRC Edition
Sep 2, 2004 - 1:41 PM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
http://www.vortechsuperchargers.com/produc...l/fuel_fmu.html
if you get a 12:1 you can get this to change ratios -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 2, 2004 - 2:08 PM |
Why not get the higher pressure one and a regulator in case you need more down the road?
Sep 2, 2004 - 8:13 PM |
Enthusiast Joined Sep 22, '03 Currently Offline Reputation: 0 (0%) |
i got a 10:1 Vortech.. just to be safe
Sep 2, 2004 - 11:50 PM |
well I only plan on running around 5-6psi tops and 3 for daily driving.. so I don't wanna run rich all the time.. thats why im leanin towards the 4:1 now instead of ne of the others.. was gonna get the 12:1 just cuz of the price... who knows but I gotta figure something out..
The 5sfte will work without a FMU correct? -------------------- 99 project version 3.0.. hello SEMA 2010 =) |
Sep 3, 2004 - 1:23 AM |
only if u have bigger injectors and a 2 bar map SAFC would work too -------------------- 1994 Celica GT4 WRC Edition
Sep 3, 2004 - 1:34 AM |
I got the 2 bar map and workin on bigger injectors, got the supra TT pump also... just cant seem to figure out if Its the green or yellow tops I need.. belive green but can only find yellows
Lo-Fi Version | Time is now: January 16th, 2025 - 12:56 AM |
