6 Pages V  < 1 2 3 4 5 > »
> The 5sfTe thread, Lets see what you've got.
post Sep 10, 2004 - 9:35 AM
1bwilson
Joined Aug 30, '02
From Maryland
They are really good guys. I like that site alot.
Member of Team 5sfTe
post Sep 12, 2004 - 11:11 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
my friend wanted to use my MBC as a template to make there own like i did. but when i got mine back and puit it on i was boosting at 14 psi!!!
was CRAZY i was so scared as soon as i noticed it pull harder than normal i looked at hte guage and let off the guage instantly. Mmm i want more boost.
hi im john and im a boost addict.
post Sep 12, 2004 - 11:22 PM
celicarocker
Joined Sep 25, '03
From cranston RI
QUOTE (x_itchy_b_x @ Sep 13, 2004 - 12:11 AM)
post Sep 13, 2004 - 3:08 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
One step closer.. tryin the Air Press reg Idea that I had.. might work.. might not... well see... think I will have to bump up to larger piping though...
? for you 5sfte guys.. how did you connect your oil lines to the intlet line on the turbo.. like an special fitting?
Thanks
NEVER
post Sep 13, 2004 - 6:25 AM
1bwilson
Joined Aug 30, '02
From Maryland
I like that alot!!!! Very well done.
post Sep 13, 2004 - 10:58 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
yeah thats awesome. um hope it works out oil leaks suck. it should work thogh looks nice. yeah we cut the line out of the tock flange then tapped the holes to make those brass fittings thread in. then welded them in once they were in.
post Sep 15, 2004 - 6:54 AM
ice23q
Joined Jan 16, '04
From sydney australia
i am using red injectors from a 4agze......have had no probs and runs real smooth
312whp with more to come....
post Sep 15, 2004 - 7:40 AM
Akimbo
Joined Jun 30, '03
From O-town, FL
You guys have some awesome projects there.
- Ryan
aim: rkgreen04
post Sep 15, 2004 - 7:43 AM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE (ice23q @ Sep 15, 2004 - 4:54 AM)
Strange... I guess they fit. Hows your kit running? How many mikes have you been running it and what psi?
post Sep 15, 2004 - 10:09 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
QUOTE (1bwilson @ Sep 15, 2004 - 8:43 AM)
yeah. espcially without an intercooler? just wondering.
post Sep 15, 2004 - 11:19 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
QUOTE (x_itchy_b_x @ Sep 13, 2004 - 3:58 PM)
i made my own flange from 1/2" aluminum and tapped it to 3/8" pipe thread on the oil return side and then 1/4" on the oil inlet then get some of those stainless steel hose fittingsl like aeroquip or earl's or russel or even a brass fitting from a hardware store and make sure it's pipe thread and bam your done.
there has to be another way to restrict the oil uhmm a valve maybe anyone have any ideas
This post has been edited by rjbibeau: Sep 15, 2004 - 11:19 AM
post Sep 16, 2004 - 12:20 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
maybe u where referring to my idea..maybe not.. if not then scroll up a few replies wink.gif
189$ shipped
2.25 ID
post Sep 18, 2004 - 12:35 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
hehehe one step closer... beads needs to be cleaned up and everything painted but u get the idea
post Sep 18, 2004 - 12:37 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
wink.gif Mmm.
post Sep 18, 2004 - 3:37 PM
Irishflame27
Joined Sep 3, '04
From Avondale, AZ
lookin awesome Never!
post Sep 20, 2004 - 4:19 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
current engine pic
post Sep 22, 2004 - 12:55 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
Looks great itchy! thats almost identical to the layout I have for me IC piping biggrin.gif
Heres what I got done last weekend for the turbo project... basically freed up some room in the engine bay for piping and for the cold air box im working on.. did this by relocating the battery to the trunk.. was pretty easy.. used a set of jumper cables for the battery lines and some non fused distribution blocks for the terminals.. works good but need a stronger battery.. the "ECONOMY" just isnt cuttin it for me tongue.gif
newayz heres some pics
and here is the absolute safest and cheapest method of turboing your celica!
post Sep 27, 2004 - 5:02 PM
1bwilson
Joined Aug 30, '02
From Maryland
That looks good, Thats the same thing Im doing with my batt. Where did you get the distro blocks? What gauge are they?
My motor is about to turn 500 miles tomorrow so Im going to be doing the first oil change on it to see if everything is clean, no metal shavings. Then its on to the 1000 mile road test and then another oil change.
500 miles and I havent poped a rod, 3sgte rods do fit 5sfe pistons with some mods to the crank.
post Oct 18, 2004 - 9:43 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
1bwilson. ur 5sfte is gonne be a REAL insane motor done right in every way. awesome. Never any updates?
post Oct 18, 2004 - 1:50 PM
1bwilson
Joined Aug 30, '02
From Maryland
Im going to be doing my oil filter re-locater tomorrow and then maybe my batt re-locate also. I'll try and get pics of it when I finnish. 700 miles and still running. I think I'm going to do a comp check also. Never done one.... any suggestions on how?
Lo-Fi Version Time is now: January 12th, 2025 - 9:47 PM
