car wont start, why |
Sep 2, 2004 - 7:02 PM |
Enthusiast Joined Sep 6, '03 From hudson ,iowa Currently Offline Reputation: 1 (100%) |
ok so i finish up my turbo and prime the turbo and then i go to start car and nothing happens just cranks and doesnt fire , so shecy everthing oner looks good, check to see if i ahev spark and i do theni check for fuel and i can already smell that so thats good, i cant seem to figure it out anybody got any ideas
Sep 2, 2004 - 7:11 PM |
Enthusiast Joined Nov 27, '03 Currently Offline Reputation: 0 (0%) |
Did you check all of your ignition? Distributor cap and rotor and plug wires?
Sep 2, 2004 - 7:39 PM |
yah it getting spark
Sep 2, 2004 - 8:08 PM |
Enthusiast Joined May 7, '04 From Concord, NH Currently Offline Reputation: 0 (0%) |
Ecu codes ?
Missing any grounds ? coil good ? Try jumping it? What tha battery reading when you try and start it? whats the battery normally reading? Dr. |
Sep 2, 2004 - 8:12 PM |
Enthusiast Joined Jul 10, '03 From Appleton,WI Currently Offline Reputation: 0 (0%) |
Gas?...I have seen it happen...
-------------------- A Jaws4God Creation... |
Sep 2, 2004 - 8:17 PM |
yah its getting gas cuase after you try cranking it you can smell it
Sep 2, 2004 - 10:49 PM |
clogged injectors? when i had to get my car started the very first time i had to lean it out it was running to rich. then after it was started i richend it and it was fine. proper spark plug gap also? -------------------- |
Sep 3, 2004 - 7:40 PM |
bump
Lo-Fi Version | Time is now: January 16th, 2025 - 2:35 PM |
