> people with aftermarket gagues
post Sep 2, 2004 - 8:18 PM
macavely
Joined Nov 4, '02
well just installed mine today got them used ... well just wanted to know were did you get your power from? i hooked mine up to the sound system but they are not lighting up...
post Sep 2, 2004 - 9:45 PM
best thing to do is buy a multimeter. then you can start testing what wires get 12v when you turn your headlights on. for my gauges i taped into the light that goes around the sig lighter.
what guages did u buy?
This post has been edited by lagos: Sep 2, 2004 - 9:46 PM
post Sep 2, 2004 - 10:33 PM
Tru_Pol
Joined May 3, '04
From Alhambra 62001
I hooked mine up to the red wire for the sterio. That wire powes when you turn the car on. Mine light up fine. For the Volt gauge I just ran a wire off the battery so I can watch my voltage at all times (when the carns not running and the sterio is on).
J-
post Sep 3, 2004 - 12:11 AM
Green wire at the dimmer I think. That is a positive and only gets power when the parking lights are turned on.
post Sep 3, 2004 - 9:32 AM
turboinduction
Joined Feb 25, '04
From Wisconsin
brake lights in the fuse box
simple, easy, and right next to the gauges... w00t!
post Sep 3, 2004 - 10:06 AM
QUOTE (turboinduction @ Sep 3, 2004 - 7:32 AM)
Although if you tap into the brake light fuse, your gauges will constantly be on. wink.gif
post Sep 11, 2004 - 9:31 PM
ryguy1231
Joined Feb 26, '03
From Minneapolis, MN
Another easy (and awesome wink.gif ) way is to hook it up to your ignition. Then they light up the second you turn the key.
post Sep 11, 2004 - 10:12 PM
ShadowFX
Joined Jan 22, '04
From WA, Australia
I would think park lights (Dimmer) would be easy (and practical) like batman said, since your stock gauges only turn on when your lights are on, which makes sense to me. my 0.02
post Sep 11, 2004 - 10:27 PM
chucho
Joined Mar 23, '03
From New Orleans
QUOTE (lagos @ Sep 2, 2004 - 9:45 PM)
me too
post Sep 11, 2004 - 10:34 PM
Jaws4God
Joined Mar 27, '04
I ran mine to the dimmer switch. It just made sense to me so that they come on when my headlights are turned on. :-)
This post has been edited by Jaws4God: Oct 9, 2004 - 1:33 PM
post Sep 29, 2004 - 12:03 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
hook it it up to your illumination wire on the stero on the aftermarket harness.
post Sep 29, 2004 - 4:24 AM
shadycrew31
Joined Jun 29, '03
From canoga park , ca
well all that is tricky stuff guys. heres what ya do theres a bunch of lil light behind the guage pannel. pull out the pannel as a whole. there should be a green palstic computer board on the back of it. pull out a light(black palstic plug) put the wire in the hole. make sure the wire is conecting with the copper toned circle that the light goes in. put the light back in.. and bam now anytime you start the car lights go on you wont blow anything and you dont have to run alot of wire.
Lo-Fi Version Time is now: November 27th, 2024 - 11:42 AM
