> horsepower, those little chips on ebay
post Sep 4, 2004 - 2:59 PM
brys99
Joined Aug 7, '04
From Ohio
i was just wondering if anyone ever put on one of those chips that supposedly add 20+ horsepower that are CHEAPly sold on ebay. i see they just attach to a sensor, but i was wondering if anyone could tell me if it was a worthwhile purchase or some stupid piece. thanks
post Sep 4, 2004 - 3:11 PM
o8poa8o
Joined Jun 11, '04
From Wake Forest, NC
man i wouldn't trust those, there what .99 cents! i doubt it does anything.
post Sep 4, 2004 - 3:26 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
i guess all it does is make the ecu think its getting more air thus giving more fuel. but sounds like bull**** to me. i wouldnt trust it either.
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Sep 4, 2004 - 3:30 PM
blkGT
Joined Jun 10, '03
From FL
i bet it adds 25-50 hp
post Sep 4, 2004 - 3:57 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
ditto
post Sep 4, 2004 - 4:49 PM
shid
Joined Jan 8, '04
From LA
tricks the ECU, yeah
Does it add HP? yup. Is it safe? nope. Can/Will either harm the engine, or the ECU
post Sep 4, 2004 - 4:56 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Ha maybe i should try it out when im ready to pull out my engine .. or if someone is getting ready to swap.. try it out..
post Sep 4, 2004 - 5:23 PM
celicaspeed
Joined Aug 22, '04
From kitchener,Ontario
It works!But it is a easy way to pop your engine on a hot day.It tells your computer that its getting cooler air then it advances your timing 2 degrees and then pop there goes your motor.Its a fifty cent resistor.your motor $800-$1500.Watching someones car blow up from a fifty cent chip=PRICELESS
post Sep 4, 2004 - 5:44 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (celicaspeed @ Sep 4, 2004 - 10:23 PM)
You really don't know what you're talking about at times dude...
And to add to everyone else's guesses... it does trick the ECU... but it tricks the ECU to dump more fuel. That does NOT add power to our cars...
This post has been edited by Kwanza26: Sep 4, 2004 - 5:46 PM
post Sep 4, 2004 - 5:52 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
To end the debate...
The resistor tricks the ECU into running the car at Open Loop all the time, which the ECU runs a fixed air/fuel map that is a lot more rich than normal. That does NOT add power. Running at open loop is designed to improve cold start and other situations where the engine may struggle for a bit more fuel. That's all it does... does NOT add power... etc. Doesn't do anything to timing, and even if it does (some cars may, depending on ignition set-up)... it'll be very very slight which will most likely be because of the knock sensor or something else.
End of these useless guesses...
post Sep 4, 2004 - 9:05 PM
Ale_lock
From New York City, NY
QUOTE (Kwanza26 @ Sep 4, 2004 - 6:52 PM)
Lo-Fi Version Time is now: November 28th, 2024 - 4:09 AM
