turbo oil blowby, whats ip |
Sep 5, 2004 - 7:44 PM |
Enthusiast Joined Sep 6, '03 From hudson ,iowa Currently Offline Reputation: 1 (100%) |
ok so i finished car today and everthin works great except the btm which i will figure out later , now take car for a test run runs good abd boost well and pulls hard but anytime i get over 5 pounds and let off the i blow smoke out the exaust for a sec and then its fine , found iol right on outlet in pipes so seals are bad correct? and the turbo needs to be rebuilt ? or is there to much oil pressure going into the turbo from the oil inlet somebody help cause no i need my car back cause that was just plain fun
Sep 5, 2004 - 11:26 PM |
Enthusiast Joined Mar 31, '03 From Bowling Green, KY Currently Offline Reputation: 0 (0%) |
what color is the smoke, it all depends on that..it could be fuel if it's black smoke or major prob if it's white/blue, that means your most likely burning oil caused by one of these: bad rings, head gasket, valve seals, bearings, cracked block
Lo-Fi Version | Time is now: November 27th, 2024 - 8:09 PM |
