> My defogger is not working!!!!!, need some help!!!!
post Sep 7, 2004 - 10:46 PM
tengys
Joined Aug 24, '04
From Saginaw, MI
my defogger is not working...so anyone knows how to check or fix it???
post Sep 7, 2004 - 10:49 PM
check the fuse.
post Sep 8, 2004 - 2:38 AM
tengys
Joined Aug 24, '04
From Saginaw, MI
i just change the new fuse...and it's still not working......
post Sep 8, 2004 - 9:10 AM
turboinduction
Joined Feb 25, '04
From Wisconsin
OH NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
post Sep 8, 2004 - 9:14 AM
turboinduction
Joined Feb 25, '04
From Wisconsin
actually, check this....
Look at your defroster lines. Look REAL close. Check to see if something went across them breaking the line. Like you were loading/unloading something and scraped the glass. If these lines have even the smallest break in them, they wont work. If you find a break, go get a fix (like liquid copper or something) and patch'r up. Good luck.
If not that, check this...
Fog up dem mirrors! Hit your defroster button. If your mirrors dont defrost then you have a problem with the defroster itself, if they do, well at least you know its not the defroster and head towards the back to find the problem.
post Sep 8, 2004 - 10:13 PM
tengys
Joined Aug 24, '04
From Saginaw, MI
I'm not sure, is this the defogger relay problem or not? cos i pull it out and check it with the fuse tester, seems one set of the teminals not continuity...so i'll try to replace a new defogger relay and see how......
post Sep 8, 2004 - 10:33 PM
boosted_K2
Joined Aug 30, '02
From Michigan
do you have it on recirc air or outside air? defog/defrost doesnt work when its on recirc tongue.gif, if that aint it its probably something scratched the lines in the glass or a short in a wire.
BTW nice to see another guy from MI in here!!
if you ever wanna chat about stuff going on locally my AIM is k2mr2t91. later!
No but I don't buy it
Cause I'm...
post Sep 9, 2004 - 10:15 AM
exxtractor
Joined Mar 31, '03
From BC
Defog will defintely work if its on recirc, and works incredibly fast if you turn the A/C on... it will clear up in a few seconds.
post Sep 9, 2004 - 10:37 AM
Are you talking about rear defogger (with lines) or the front which is just redirected air.
post Sep 10, 2004 - 3:04 AM
tengys
Joined Aug 24, '04
From Saginaw, MI
Thanks guys.....It's fixed!!!!!!
post Sep 10, 2004 - 9:06 AM
Jaws4God
Joined Mar 27, '04
do you guys have a problem when its raining and the windows fogging up, but when I turn up the heat to defog them... it makes the car extremely warm.... its like a compromise between comfort and seeing... My friend and i couldn't see a thing and were cooking!
post Sep 10, 2004 - 9:46 AM
turboinduction
Joined Feb 25, '04
From Wisconsin
crack your windows to let hot air out (sunroof if you have it() and turn the A/C on to cycle cold air in. That'll fix the rain problem.
post Sep 10, 2004 - 2:20 PM
CelicaQT
Joined Sep 29, '02
From Sterling Heights, Michigan
QUOTE (tengys @ Sep 10, 2004 - 4:04 AM)
So what did you end up doing? Did you replace the relay?
post Sep 10, 2004 - 11:59 PM
Jaws4God
Joined Mar 27, '04
QUOTE (turboinduction @ Sep 10, 2004 - 2:46 PM)
thank you
post Sep 13, 2004 - 5:01 PM
tengys
Joined Aug 24, '04
From Saginaw, MI
No...not the relay problem...finally i found out the wire was burned and was disconnected.....so just replace the wire.....anyway thanks for everything....
Lo-Fi Version Time is now: December 12th, 2024 - 10:24 AM
