Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) ![]() |
well can it be done.. and if so what are gains/cons also am pretty sure this would trigger a check engine light.. how can I rewire it to fix that.
Thanks NEVER -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
really wont gain anything, not worth your trouble.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Hecho en la Republica Dominicana/Living in NJ Currently Offline Reputation: 0 (0%) ![]() |
well i was thinking about doing this.. the more i read up on the egr system... man reason for it being there is so less carbon-minoxid (sp) would get in to the air .. so by removing it you would have more fresh air into your engine and less heat also.. so i think you would get gains from it.. and other mods would gain you more power... as for not getting the check engine light.. might want to try to reposition the sensors to trick the ecm..
No man, thats wrong. You wont see any performance from getting rid of it. The EGR doesnt operate at open throttle, removing may even increase chances of detonation.
The ONLY reason you should remove it is if its not working properly or you need space in the engine bay. This post has been edited by Supersprynt: Sep 8, 2004 - 7:16 AM -------------------- |
thanks for clearing that up... -------------------- |
well those are the exact reasons I want to remove it.. Im getting a check light off the EGR system but there is nothing wrong with it as far as I can tell.. OBDIIed it and its telling me that the charcoal canister is either clogged or a line is block/pinched... well its neither of those.. have put a different canister in and also checked all lines and nothing.. have cleared the code 3 times now so it a hard code now ![]() I also need some extra space for the 5sfte install. I have also heard that removing the EGR system will generate HP gains... not nething to bragg about but gains none the less -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 20, '03 From Annapolis, Md Currently Offline Reputation: 5 (100%) ![]() |
I was going to say, My check engine light has been on for about 5 months.. an its the egr. I havnt replaced it because i figured soon after it came on.. I was gunna do the swap.. an kept pushing off the swap. an now i dont have time. I need to replace it because I will have emitions soon.. but It hasnt effected my engine at all. but should I replace or remove???
well if you have to do emmission test then you need to leave it on there.. I fortunately dont have to do emmissions yet.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 27, '02 From Derry,NH USA Currently Offline Reputation: 9 (100%) ![]() |
mine got clogged once and it ran like crapola. It can do a bad number to your engine..don't mess with it!
I talked ot my buddie an he said it would only make it worse..
97Celica what exactly happened and how did you fix it?? dont think mine is clogged cuz the car idles fine and cant find ne visual probs with it.
as for the egr system the most I can find in the toyota repair manual is that it regulates all engine conditions for the reduction of exhaust emissions.. that would tell me that its keeping the A/F mixture lean and recirrculating the blow by gas.. figure if I rerouted the blow by into the exhaust system or just to the underside of the car and capped off the air lines on the intake manifold... kinda like an aftermarket intake manifold it would run fine.. would trip up a check engine light but have that already and im sure there is someway to rewire it to not trip the check engine. I want to know if it will hurt my motor in anyway if removed.. I understand that if there is problems with the EGR it would possible affect performance.. kinda like you remove one of the vaccum lines from the throttle body and the car stalls.. but I wanna know if its completly removed will it hurt nething. Example will I have to clear it out of the ECU... like 0's accross the board for the EGR?? Pretty sure that the JDM/European specs didnt have EGR's... could someone confirm this for me? K2 u posted about this once a while back.. u got ne tips? Thanks NEVER -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
Enthusiast ![]() ![]() ![]() Joined Jul 7, '04 From charlotte N.C. Currently Offline Reputation: 0 (0%) ![]() |
im pretty sure i remember something about jdm having a internal egr.
also can someone confirm that jdm emissions are a lot stricter than they are here. -------------------- Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph. Next: maybe an elise |
My EGR valve was clogged, blackish smoke kept comin out of my exhaust and it was rough idling..I did a tune up and it didn't help..My engine check light kept coming on and I brought it to my uncle's shop..I hooked it up to the computer and it said it was EGR related..So, I ordered a new one and installed it the next day..It's simply 2 bolts and a gasket..my old one looked like there was black charcoal chunks stuck in it and the cylinder to allow the air/fuel was messed. My uncle said it was probably because of all the fuel additives I used to run and because of my running the engine harder than normal.
Enthusiast ![]() ![]() ![]() Joined Mar 20, '04 Currently Offline Reputation: 3 (100%) ![]() |
my check light is still on after a year and 2 egrs from toyota. Dont know what is going on shop told me not to worry about it and it has been a year and it hasnt gave me any problems.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 27, '03 From Nor Cal Currently Offline Reputation: 0 (0%) ![]() |
I don't think removing the EGR system will actually solve your code issue. That's one of the annoying things about OBDII (tries to think for itself too much). I think there is a way to be rid of the code and the EGR system... but let me check up on that and I'll try to get back to you guys...
-------------------- "It's ok to be naked girl... I'm an artist!"
LOL I was just gonna IM you kwanza about your opinion on this... let me know - still undecided
thanks edit: keep in mind this is for a 5sfte project and I will be running 93+ octane This post has been edited by NEVERSTOP: Sep 9, 2004 - 12:08 AM -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
=] Basically, the EGR cleans up unburned gases and recirculates them through the intake system. It won't necessarily harm a turbo set-up or anything like that, but if it's in the way, you can remove it. It's not the actual removing of the system that will do anything, but it's whether the ECU likes it or not (damn OBDII). The ECU will most likely throw codes if the EGR is removed... and that with a turbo set-up can lead to unknown circumstances. Again... damn OBDII trying to think for itself! (great for smog techs... bad for tuners)... I'm sure there's a way to work around it... so i'll do some read-up at our shop tomorrow and see if I can come up with anything... -------------------- "It's ok to be naked girl... I'm an artist!"
well what I can come up with threw reseach on it is this:
The EGR isnt really nessary but does help to a certian degree with detonation. basically the EGR isnt functional at WOT but does help with midrage detonation. the thing is that you will encounter almost no midrange detonation newayz so there isnt much point. some people say that the most cons they notice are: higher temp timming issues some detonation but alot of people seem to have done it with no cons Pros: no nasty build up in throttle body/intake manifold more space Some say that doing this will lower the intake temp by not using exhaust gases.. others say it will raise combustion temp by the lack of spent carbon in the combustion chamber personally I think it would allow a little more a/f mix into the chamber... and well... "my daddy always told me it took gas to go fast" ![]() ![]() really dont think it would make a difference though HP/performance wise that would be noticable.. do think it would provide a cleaner running engine longer as there would be less build up in the Intake side of things.. but a Oil catch can would do that also for me.. which I have one...would just need to figure out what exactly is tripping up the CEL... Kwanza.. did read that there is a electrical fix to the CEL but not sure what it was off hand.. www.mr2oc.net has the topic there.. will link if I can find agian BTW.. OBDII was the worst thing ever invented... -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
Enthusiast ![]() Joined Dec 2, '03 From Virginia Currently Offline Reputation: 0 (0%) ![]() |
Unless you will be running a stand alone I would not remove the egr on a modern car. It reduces NOX which occur at combustion temperatures > 2500 i think, by diluting the A/F with exhaust gases to lower the combustion temperatures. During warm-up, idle, wot the egr isn't even on. The ecm also depends on the functionality of it, and will advance timing, or reduce injector time during high egr operation to reduce and sometimes improve the performance of the engine. The ecu uses a egr gas temperature sensor to determine if the egr is working or not. Low egr flow can cause detonation, and no flow can cause severe detonation, especially if the ecm is counting on the egr working.
This post has been edited by Snarfer: Sep 9, 2004 - 12:45 AM |
Snarfer - will be running MSD 6BTM and Vortec 8:1 FMU... or where you referring to ECU? This post has been edited by NEVERSTOP: Sep 9, 2004 - 12:46 AM -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
Lo-Fi Version | Time is now: February 17th, 2025 - 2:15 AM |
