![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) ![]() |
will have pics soon. as it states, combo set of a HKS FCD (fuel cut defender) and a Restriction style MBC (manual boost controller). all you need to get seperately is a set of 2 silicon vac hoses and you will have everything you need to adjust your boost pressure.
if using the FCD on a 2nd gen 3sgte motor, setting # 7 will eliminate the fuel cut and setting #9 sets it to 17.5 PSI best offer takes it, basic price for the MBC is 35 bucks and a brand new FCD is a little over 100. this FCD is slightly used but in good working shape. also this restriction style MBC does NOT require you to disconnect the T/VSV. -------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) ![]() |
how much for the got boost sticker?
2 bucks + shipping
![]() ![]() -------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
bump
sale pending on the FCD, got boost sticker and MBC still for sale, 35 shipped.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '02 From Webster Ma. Currently Offline Reputation: 1 (100%) ![]() |
the FCD u think that will work on my 5sfte? since im using a 3sgte map (turbo senor)?
the FCD doesnt deal with the sensor, it deals with the ecu. i wouldnt expect you to need it because it removes the fuel cut due to pressure spikes, the 5sfe doesnt have a boost pressure sensor, so it wouldnt do anything for ya.
Lo-Fi Version | Time is now: February 24th, 2025 - 6:35 PM |
