> high pitch sound while accelerating, help
post Sep 15, 2004 - 3:22 AM
do_0b
Joined Feb 17, '04
From milpitas CA
Hi, my 94 gt auto is occationaly making a high pitched sound while i acclerate. it kinda sounds electronic, kinda like a rc car. it would only be while im stepping on the gas and it would go away if i let off the gas or brake. and when i come to a complete stop you would hear it again while decelerating from around 2k rpm. does anybody have any idea what this is?? any help would be greatly appreciated
post Sep 15, 2004 - 6:24 AM
recneps
Joined Jul 7, '04
From charlotte N.C.
i had that problem, in my auto lude mine was coming for the speakers. somehow the engine was making the speakers make sounds. try turning off your radio and see what happens. i kinda sounded like my car was superchanged. biggrin.gif
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Sep 15, 2004 - 10:46 AM
Anub1s
Joined Nov 27, '03
When I had the aftermarket stereo in my car I found out that the antenna wasn't entirely grounding, so when I had it on the radio, it would make that high pitched sound while accelerating but only on certain stations in certain places...it was really wierd, then I put the stocker back in and it was all fine.
post Sep 15, 2004 - 10:55 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
it could also be the electrical interfearence from your spark plugs. they make grounding kits for this kind of problem
post Sep 15, 2004 - 10:57 AM
shid
Joined Jan 8, '04
From LA
Bad ground somewhere. Most likely the head unit/CD player. Upgrading the grounding kit won't fix it. You're hearing it on deacceleration because the engine downshifts and the revs temporarily increase for a couple seconds. It's called engine noise, and it's quite common. Check the grounds of any custom equipment you have installed; I grounded everything to the same point and it's worked great since then.
post Sep 15, 2004 - 11:08 AM
I'm with shid...it's most likely a bad ground somewhere.
post Sep 15, 2004 - 4:31 PM
MK153
Joined Apr 13, '04
From St. Louis (Webster Groves)
Are you RCA patch cables ran on the same side as your power cable? This is assuming you have installed a system...
If so get them atleast 18" apart and it will go away.
post Sep 15, 2004 - 7:17 PM
exxtractor
Joined Mar 31, '03
From BC
The sound they are talking about is called "alternator whine".
Do as they have suggested obviously we are all assuming you have recently installed some car audio equipment. The only thing I will tell you is that my deck when 4 RCA pre-outs are pluuged in produces alternator whine, just running 2 preouts, and using hte amp's internal splitter, no "whine". So equipment sometimes can be blamed for the whine, and just not a bad ground.
This post has been edited by exxtractor: Sep 15, 2004 - 7:18 PM
post Sep 15, 2004 - 7:46 PM
shid
Joined Jan 8, '04
From LA
QUOTE (exxtractor @ Sep 16, 2004 - 12:17 AM)
Ground your amps to the same spot, or buy a radioshaq ground loop isolater, and use all 4 RCA preouts smile.gif Your problem isn't the equipment, but the grounds still.
THanks for getting the correct name, I forgot what it was called exactly
RCA and power on the same side will cause distorted/lessor quality signal, not whine
post Sep 15, 2004 - 8:31 PM
do_0b
Joined Feb 17, '04
From milpitas CA
ok thanks for all the replies guys. i thought it was something with my engine and i got really scared. the only electronic thing installed are indigo gauges and i grounded it with a bolt on my door. I have a pioneer deck and its been there for a long time. the gauges have been there for a few months already and i just recently heard all this noise.
post Sep 15, 2004 - 9:59 PM
MK153
Joined Apr 13, '04
QUOTE (shid @ Sep 16, 2004 - 12:46 AM)
RCA and power on the same side will cause distorted/lessor quality signal, not whine.
Well thats just not true... my old bronco whined excessivly when I had both run on the same side, after I moved the RCA to the other side of the car it stoped completly. My friends only mustang did the same thing, we moved the RCA to again correct the problem.
post Sep 15, 2004 - 11:18 PM
psyko
Joined May 18, '04
From Charlotte, NC
ya my car does that it's not an auto, but my car does that in 1st gear in low rpms or reverse. It's just like a whinning sound, almost like siren, it's like a winding up or somethin, kinda weird, but i think it just doesn't like to be at low rpms in low gears, like 1st or reverse frown.gif. no big deal really.
post Sep 16, 2004 - 12:19 AM
shid
Joined Jan 8, '04
From LA
QUOTE (MK153 @ Sep 16, 2004 - 2:59 AM)
Maybe we're defining whine differently.
post Sep 16, 2004 - 12:06 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
but whine/squeal/crack/pop
all hard to imagine...
belt only if does it for first few mins after start-up AFTER sitting for period of time.
post Sep 17, 2004 - 7:45 AM
creis
Joined Jan 10, '04
From Shoreline, WA
Mine did that for a wile right after i hand my head machined, and got new valve guides in. I though it was kinda cool sounding, but it went away. It sounded kinda like a weak supercharger/turbo wisle. I think that it would be hard to mistake a noise coiming from the sterio rather then the motor but thats just me.
Lo-Fi Version Time is now: December 1st, 2024 - 7:45 AM
