> problem with engine temperature, need help
post Sep 16, 2004 - 10:17 PM
pimped6gen
Joined Sep 16, '04
From Hershey, PA
Within the last week or so i have been noticing that my engine temperature has been fluctuating quite a bit while i drive. I will look at it for one second and it would be up about half way ( a little more than normal) and then drop down to a 1/4 inch above C for cold. What may be causing this? Any ideas? I had my oil changed about a week ago when i started noticing this, could that be it? My coolant level is fine also! hmmmm
post Sep 16, 2004 - 10:32 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
check the thermostat take it out then put it in water and boil it. if that works then get a coolant flush done or it could even as simple as the sensor going goofy.
Lo-Fi Version Time is now: December 1st, 2024 - 6:03 AM
