3 Pages V  < 1 2 3 >
> PICS of the 3SGTE Swap!, here they are...
post Sep 21, 2004 - 11:42 PM
jgreening
Joined Jan 17, '04
From Illinois
I bought the MR2T clip from Ricky's Auto in Miami. My experience was OK.
post Sep 22, 2004 - 10:46 AM
95BlueGT
Joined Aug 30, '02
From Austin Texas
dyno??
post Sep 22, 2004 - 11:26 AM
jgreening
Joined Jan 17, '04
From Illinois
No dyno. No reason to. Once the boost is turned up to 14, I will be running about 220 or 230 whp. If I get a new turbo or EMS someday, I may get it dynoed in conjunction with tuning.
This post has been edited by jgreening: Sep 22, 2004 - 11:27 AM
post Sep 22, 2004 - 9:30 PM
jgreening
Joined Jan 17, '04
From Illinois
pics posted
post Sep 22, 2004 - 9:33 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
wow JAMASCO did a awesome job. your car is amazing.
just curious how much did they charge for the swap including everything you ahd done?
This post has been edited by recneps: Sep 22, 2004 - 9:33 PM
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Sep 22, 2004 - 9:35 PM
jgreening
Joined Jan 17, '04
From Illinois
Labor was about 2K. The wiring alone was $625. I have over 5k in parts and miscellaneous expenses.
post Sep 22, 2004 - 10:45 PM
man, i really need to get my pipes weled.
post Sep 22, 2004 - 10:49 PM
Yota
Joined Feb 27, '04
From Illinois
was the wiring ($625) part of the $2000 in labor?
post Sep 22, 2004 - 11:04 PM
ghostdog
From ny to philly
I'm gonna be the first to call bs on this whole thing. the pictures say 1961.05.06 and it is CLEARLY not May 6th 1961 wink.gif
j/k. nice pictures man. I'm deathly jealous
post Sep 23, 2004 - 8:18 AM
jgreening
Joined Jan 17, '04
From Illinois
Yes.
It is BS that I have figured out how to operate my new digital camera properly...laughs.
This post has been edited by jgreening: Sep 23, 2004 - 8:19 AM
post Sep 23, 2004 - 10:58 AM
Akuza
Joined May 2, '03
MORE BRIGHTER PICS !!!!
post Sep 23, 2004 - 11:50 AM
looks GREAT man...real nice job on the IC piping, looks real clean!...mmmm BOOOOST wink.gif
post Sep 23, 2004 - 9:37 PM
Anub1s
Joined Nov 27, '03
w00t go jgreening. Kudos on the swap and have some serious fun with it!
post Sep 23, 2004 - 9:41 PM
boosted_K2
Joined Aug 30, '02
From Michigan
QUOTE (jgreening @ Sep 22, 2004 - 11:26 AM)
without a turbo upgrade or a few other supporting mods, id say about 205-215 is more reasonable. with the MR2 transmission, you are looking at about a 10-20% drivetrain loss depending upon condition. bone stock MR2s dyno out at 182 or less at the wheels. rule of thumb for boost increases is approximatly 10WHP for every added PSI as long as it is within the turbos optimum range. +2 PSI will yield approximatly 20 WHP... 180+20+maybe 10 for the intake/exhaust combo = ~210. to gain more HP by opening up the air flow restrictions, you are missing the 2 biggest ones, primary cat (which a downpipe will replace) and the AFM sensor. those two things will yield you a bigger gain.
No but I don't buy it
Cause I'm...
post Sep 23, 2004 - 10:01 PM
Shigexile
Joined Oct 30, '03
From IL
that's awesome that we have a 3SGTE guy in IL now. tongue.gif The car is sweetness!! Congrats on the swap
post Sep 23, 2004 - 10:04 PM
jgreening
Joined Jan 17, '04
From Illinois
Tim, you know alot more about these cars than I do. That said, I got my information from the MR Controls power primer. According to that primer, the stock USDM 3sgte at 15psi with no other mods gives 200rwhp. Since I indicated that I was only planning to raise mine to 14psi, subtract 10whp to 190. The primer also indicates that you get 2-3 whp from an aftermarket intake and 10 whp from a 2.5" mandrel bent exhaust. This would have me up to at least 202. Keep in mind that JDM ECU is 21 hp higher than the USDM. Taking out the 10-20% loss through the drive train would have me in the 219-221 whp range. Thats with a 2psi cushion for safety because with an aftermarket intercooler, you get up to 16psi safely but according to the primer that adds only another 5whp. So, about 220 whp with room to go up to 235whp safely. I know this isn't exactly scientific but I wasn't trying to inflate the numbers either.
Here is the link:
3sgte Power Primer
I am curious if you still disagree.
- Jay.
This post has been edited by jgreening: Sep 23, 2004 - 10:06 PM
post Sep 23, 2004 - 10:06 PM
boosted_K2
Joined Aug 30, '02
From Michigan
and i love that power primer, very good start for basic 3sgte modifications. i was planning on getting their hydra-nemisis system later on and convert to MAP sensored instead of AFM, but i guess that all goes to the way-side now frown.gif
Cause I'm...
post Sep 23, 2004 - 10:12 PM
boosted_K2
Joined Aug 30, '02
From Michigan
and FYI i was also getting my crude ballpark figures from previous testing done on mr2s, as well as the mrcontrols power primer smile.gif
Cause I'm...
post Sep 23, 2004 - 10:20 PM
jgreening
Joined Jan 17, '04
From Illinois
I wasn't critisizing....real world experience is to be valued over mere reading....
post Sep 23, 2004 - 10:33 PM
boosted_K2
Joined Aug 30, '02
From Michigan
i didnt take your comment as criticism, FYI was merely an afterthought kind of like a friendly PS, sorry if it was taken otherwise.
Cause I'm...
3 Pages V  < 1 2 3 >
Lo-Fi Version Time is now: January 14th, 2025 - 6:44 AM
