> shift knob question, help
post Sep 20, 2004 - 8:40 PM
Stellar1022
Joined Aug 20, '04
From VA
Okay so i bought a new shift knob from Gilbert which is great. But the new knob is a little shorter than the stock knob so there is a small gap of maybe 1/4 inch between the bottom of the knob and the boot. So i was thinking i could just cut the shifter (the actual metal bar) down a little bit so it was flush. In doing this i would be cutting off some of the thread. So if i do cut a small portion of the thread would i still be able to put my stock shifter back on if i wanted to. thanks guys. any sugestions are welcome
post Sep 20, 2004 - 9:12 PM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
Chances are you'll bend the threads where you cut it. I dunno dude...
post Sep 20, 2004 - 9:17 PM
Stellar1022
Joined Aug 20, '04
From VA
Well the new knob doest attach by the threads so worse case is id just stick with that. but id like to have to option of putting the stock back on. I was more worried that if i cut the shifter down the stock knob wouldnt have enough thread to be tight.
post Sep 20, 2004 - 10:11 PM
Stellar1022
Joined Aug 20, '04
From VA
Can i adjust the height that the boot comes up to make it come flush with the knob.. or can that not be changed... does it just sit where it naturally is.
post Sep 20, 2004 - 10:15 PM
ghostdog
From ny to philly
yeah I cut the stock shifter. its kind of ghetto but it lets the shifter sit a little lower which I like.
post Sep 21, 2004 - 2:53 PM
C3L1CA
Joined Mar 11, '04
From Oakdale, MN
You should be able to move the to of the shifter boot down or up a little. There is a little circle thing holding it where it, is just pull it up
-Brad
01 a4: daily
post Sep 22, 2004 - 10:15 PM
mikew04
Joined Feb 19, '04
From austin tx
The problem with that is if you want it to move up, it probably wont stay, and if you want it to move down, you have to bend it, making it hard to stay in its original position if you go back to stock.
post Sep 24, 2004 - 1:47 PM
trdevelopment
Joined Jul 27, '04
From phoenix az
ohk stellar this is what you do. first you cut the rod in your words(metal peace) go to home depot and get the tool that makes new threads make sure its metric i forgot what the tool was called they should know what your talking about but i know its not more then 10 bucks and go home then go home and make new threads on the bar.
post Oct 24, 2004 - 10:41 AM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
IMGC:\Documents and Settings\davd robinson\My Documents\My Pictures\in celica after.jpg[/IMG] this is a TWM with a 1st Gen Mr2 shifter
post Oct 24, 2004 - 4:53 PM
C3L1CA
Joined Mar 11, '04
From Oakdale, MN
-Brad
01 a4: daily
post Oct 24, 2004 - 7:17 PM
DamDirtyApes
Joined Apr 22, '04
From Rhode Island
i think its called a dye .
post Oct 24, 2004 - 7:38 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
haha you cant link things off you HDD, man best thing ive seen in a while.
no offense man.
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Oct 24, 2004 - 8:43 PM
Sev408
Joined Dec 4, '03
all you need to do is move the plastic ring which holds the boot up farther up towards the knob. DONT CUT ANYTHING!!!!!
user posted image hows it taste motha f*cka
post Oct 26, 2004 - 12:58 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
as long as you use a hack saw and cut straight across you'll be fine. don't use a grinder because the metal will melt and mushroom out and then you'll be jacked. just hack saw it up. and finding a dye that big is kind of hard esp since it's metric. you might have to hit up a sears or order it offa the net. most stores only sell it either as standard sizes or they have a kit with metric and standard in it or just a kit with metric seperate.
post Oct 26, 2004 - 2:33 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
hehe - his name is David Robinson
--you gotta upload on the net, like photobucket
I would move the boot or get a short shifter like TRD or TWM
-Ti
post Oct 26, 2004 - 4:49 PM
Yota
Joined Feb 27, '04
From Illinois
this is all you have to do...
Move the plastic ring up, then take electrical tape and wind the tape around the shifter right below the ring. Wrap the tape around like 10 times, so the ring cant slide down the shifter.
I got a TRD knob that I had to do this with.
Its simple.
Lo-Fi Version Time is now: November 23rd, 2024 - 11:56 PM
