> Front bar removal
post Sep 21, 2004 - 5:09 AM
ShadowFX
Joined Jan 22, '04
From WA, Australia
What bolts are required to be removed to take off the stock front bar? I know its noob but hey.. =P
post Sep 21, 2004 - 7:04 AM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
What's the front bar?? Do you mean the aluminum reinforcement behind the bumper? If so, I wouldn't take that off unless you want to become a sardine in an accident. tongue.gif
post Sep 22, 2004 - 9:55 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
how do you make it not show in the invader dront. how would you even go about fighting an intercooler in there with the bar? i had to take mine out to fit my invader on. i had no other way around it.
post Sep 22, 2004 - 10:00 AM
Tru_Pol
Joined May 3, '04
From Alhambra 62001
QUOTE (rjbibeau @ Sep 22, 2004 - 2:55 PM)
From what I have seen you need to modify the front bar to make it all fit. But dont just take it off, if you get into a small accident you deploy (sp?) your air bags, even if you rearend someone around 5mph. Some insurence companys also might not cover you if you remove it. Its put on for your protection. If you hit someone at say 60mph.......well you should order your plot of ground now, and pick a nice box to be put in the ground in.
J-
post Sep 22, 2004 - 6:31 PM
jbnery6465
Joined Sep 14, '04
From SaN DiegO, CaLi
dont ever remove that reinforcement bar...thats crazy!! if your thinking of putting a fmic...just trim off any excess fiberglass from the inside of the front if you can...if not...try going top mount or something and jus get a hood scoop...lol.but i've seen it done before...its doable.
post Sep 22, 2004 - 6:41 PM
i have the invader front WITH that bar......just grab a sander and start sanding the back of the bumper around the parts were the bar hits it...eventually you will be able to slide it on WITH the bar......then you grab some black paint and spray the bar so it blends in with the rest of the car smile.gif
post Sep 22, 2004 - 11:03 PM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
and while your sanding your kit, cut the corners off the ends of the reinforcement bar with an airsaw. it still protects you but isn't as in the way. Then paint the bar black and it's gone. smile.gif
post Sep 23, 2004 - 3:30 AM
ShadowFX
Joined Jan 22, '04
From WA, Australia
lol no i meant the stock front kit, the painted part.
post Sep 23, 2004 - 9:44 AM
what stock front kit? if its stock why wouldn't it fit?!?!?!?! but you can't cut that bar! thats very very illegal and you won't pass anything like that
post Sep 23, 2004 - 10:36 AM
recneps
Joined Jul 7, '04
From charlotte N.C.
are you talking about the bumper cover?
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Sep 24, 2004 - 9:00 AM
ShadowFX
Joined Jan 22, '04
From WA, Australia
yeah im talking about just the front bumper cover, the painted stuff
Lo-Fi Version Time is now: December 3rd, 2024 - 4:58 PM
