Performance for ST, Turbo kit or Engine Swap |
Sep 22, 2004 - 2:14 PM |
as far as i remember, you can get full copper head gaskets that are made thicker to lower compression.. also looking around for some pistons, i thought the 4ag's work fine?? also, does any one know the bore/size of the 7a-fe??? |
Sep 22, 2004 - 2:22 PM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
im pretty sure its 81mm
here is a kit Geo Prism 1762cc 16V DOHC 1993-97 Engine Code Stock Bore Kit # Includes: Price 7AFE 81mm EKTO29MPX Complete Gasket Set Hussey Copper Gasket ROSS Forged Performance Pistons (81, 81.5, 82mm bore) and (8.5-1, 9.5-1, 10.5-1 comp ratio) Performance Rings Performance Wrist Pins TOGA HP Main Bearings TOGA HP Rod Bearings Thrust Washers Timing Belt Freeze Plugs $949 This post has been edited by nik: Sep 22, 2004 - 2:28 PM -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 22, 2004 - 2:58 PM |
sweet, I was woundering, caue i found an hks piston and pin set for cheap... but that seems even better cause it has everything.. but then again your also looking to have to buy a fmi witch would be another $250 + the turbo and manifold, witch would be another $1000 at least, im not sure if thats worth ..the power coing out of it.. Also where is that kit from?? This post has been edited by Digndoug: Sep 22, 2004 - 2:59 PM |
Sep 22, 2004 - 3:30 PM |
http://www.importperformanceparts.net/imports/pek-geo.html
so say 1500 in turbo parts 1000 total engine rebuild kit. and a shock engine (internal) can handle up to 170-180 wheel horse and about 190-200 wheel torque after the rebuild say coated pistons etc i think it could hit the 240 whp and 260 wtp at say 12- 14 psi just a guess -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 22, 2004 - 3:41 PM |
Enthusiast Joined Sep 14, '04 From SaN DiegO, CaLi Currently Offline Reputation: 1 (100%) |
i guess time and money for me limited b/c of school...yeah the 3sgte swap would be feasible, but i guess in my case i'd just build my 7a....enough to at least smoke some showoff civics in my area...lol...then drop a turbo, was thinking a t3/t4 so at least id get some juice in both ends...how about supercharging the 7afe??hhmmm....thanks for all the replies by the way
Sep 22, 2004 - 3:53 PM |
ok so your saying 170-180 hp.. for stock internals, then why is your turbo set only dynoing at 130hp an 160trq ??? but i guess thats also to the wheels.. Also how much power do you think a stock trany could handle , including egtting a performance clutch.. This post has been edited by Digndoug: Sep 22, 2004 - 3:54 PM |
Sep 22, 2004 - 4:04 PM |
when i dynod my car it was at 5.5 psi i'm running it at 8 psi now i havent had a chance to dyno it at that psi yet the tranny i'm not sure as for clutchs i have an oem that is hold ok but slipping im going to buy a dual friction clutch 80% clamping over stock This post has been edited by nik: Sep 22, 2004 - 4:10 PM -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 22, 2004 - 4:08 PM |
here is zipstrips dyno graph http://www.6gc.net/photo.php?file=/images/...hotos/87_23.jpg
160 horse and 170 torque to the wheels psi ?? i bought his turbo, manifold, and intercooler piping i think i'm about 165-170 horse and 170-185 torque at 8psi (a guess) -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 22, 2004 - 4:25 PM |
an thats only at 8psi, with stock internals?? |
Sep 22, 2004 - 4:43 PM |
yep stock everything for now even injectors i just bought some venom ones i'm going to push this little engine to the edge and see what it can do on stock internals -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 22, 2004 - 10:51 PM |
Enthusiast Joined Sep 3, '04 From Avondale, AZ Currently Offline Reputation: 0 (0%) |
yeah i am interested to see what the good ol' 7A can handle!
Sep 23, 2004 - 3:56 PM |
so i'm in the process of getting an greddy E-01 and msd goodies i set a date for Oct 15 to dyno and tune my car again but this time at 8 psi with some goodies.
Sep 23, 2004 - 11:52 PM |
wow man i cant wait for the results!
Lo-Fi Version | Time is now: January 18th, 2025 - 1:48 AM |
