> CAI/engine life, rumor or no?
post Sep 21, 2004 - 11:02 PM
importceli
Joined Jun 26, '04
From Bay Area, California
I know that the CAI gives you that extra air that the engine likes, but ive heard that it doesn't filter as well as the drop in filters and results in a engine life descrease. like 15-20% in some cases. Is this true or false?
post Sep 21, 2004 - 11:36 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
False, as long as you have a good cone filter. I got a k&N and love it.
post Sep 22, 2004 - 10:02 PM
mikew04
Joined Feb 19, '04
From austin tx
Theoretically, since you are getting more air into the engine, you can run it lean, which could do some damage. I dont think with a cai you are getting that much more air in, and im pretty sure the ecu and fuel injectors can keep up fine. Just check your spark plugs after running it with the intake on if youre really worried.
post Sep 22, 2004 - 10:03 PM
Anub1s
Joined Nov 27, '03
See but thats where your smart computer comes into play...it detects the increased amount of air coming in and compensates with more fuel.
post Sep 22, 2004 - 10:13 PM
ssnake86
Joined Mar 18, '04
From San Diego
hah that would explain some things. i have noticed worse gas mileage since i put the cai in. i get about 35-50 less miles to the tank then i used to
post Sep 22, 2004 - 10:20 PM
Anub1s
Joined Nov 27, '03
Are you sure you haven't been driving you car harder since you got it? Cuz mine has gotten just a tige better.
post Sep 22, 2004 - 10:55 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
CAI will not do any damage or any harm to your engine. Of course, a side-effect of installing a CAI is a heavy foot, which does increase fuel consumption and stuff. It will not make the car run lean, and it is not dangerous. It reduces air intake temperature, and increases flow velocity...
post Sep 22, 2004 - 11:50 PM
importceli
Joined Jun 26, '04
o ok because my friend was tellin me about these tests they "ran" i dunno who but it said somthin like the air wasn't as clean i unno he was trippin about it and said that life dropped dramatically. guess it aint true tho
post Sep 23, 2004 - 1:23 AM
mr_dude
Joined Feb 16, '04
From San Diego
My boss, who's a fairly knowledgable mechanical engineer, said that cone filters aren't as effective as box filters simply because they suck in air at a higher rate.
I think you should do some investigation if you're worried about it. Call K&N, since they sell both they won't lie to you.
Oh yeah, and more power generally means shorter engine life.
post Sep 23, 2004 - 11:18 AM
importceli
Joined Jun 26, '04
alright thanks man i try callin K&N
post Sep 23, 2004 - 1:52 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (mr_dude @ Sep 23, 2004 - 6:23 AM)
The reason cones are sometimes not as efficient as box, simply because of velocity. Cones tend to completely ignore velocity while box intakes have slightly more restriction thus slightly more velocity but only in the lower rpms. An intake set-up with a cone filter will outflow stock any day. That's why turbo cars and such come stock with cones...
Hehehehehe... not from an intake buddy... and not always the case.
Lo-Fi Version Time is now: November 23rd, 2024 - 8:10 PM
