> Guys, I need help!, anyone with 3SGTE in an ST...
post Sep 23, 2004 - 5:47 PM
Yota
Joined Feb 27, '04
From Illinois
I need help!! I've been doing searches all afternoon, and I'm not getting anywhere here! I need to know from someone who has swapped a 3SGTE into an ST if they have a complete part list from their swap! Also the clip i am buying is a MR2T rear clip with the LSD transmission.
So far I have:
4 brand new GT motor mounts (all of these will work, right??)
Front Mount Intercooler
I'm looking for:
88-91 V6 Camry outer halfshafts (for the MR2T transmission)
GT Throttle Linkage
Can anyone please tell me what other parts I need? I have asked around and people are giving me mixed answers, saying "yes you need this part" and "I dont know where you heard that, but you don't need this part" and blah blah blah.
Can someone please help me out? I really appreciate it..
Thanks,
Yota
This post has been edited by Yota: Sep 23, 2004 - 5:48 PM
post Sep 23, 2004 - 6:31 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (Yota @ Sep 23, 2004 - 10:47 PM)
So far I have:
I'm looking for:
GT Throttle Linkage
Thanks,
Yota
If you're gonna be working with an MR2 clip, you're gonna need shift linkages, accessory brackets and motor mount brackets (I believe it's slightly different in the MR2) and probably other little things. I believe there is a bit of custom work involved with mounting an MR2 tranny because of the mount...
post Sep 23, 2004 - 6:51 PM
Yota
Joined Feb 27, '04
From Illinois
Then whats the amount of work involved in an ST185 Celica versus the MR2T?
post Sep 23, 2004 - 8:18 PM
getting an mr2 clip sounds like a good idea in theory, but is more work in the end. ive never worked on an mr2 3s, but i know there are a few things that are not mounted the same way as the st185. the altinator is on the back of the motor insted of the front, the dipstick has to be modified, possible the power steering and the timing belft cover too.. i really dont know all the little details, but i can tell you that its going to make for a harder swap, especially since you dont have a spare 5sfe or 3sgte to take little parts from (brackets, mounts, etc).
post Sep 23, 2004 - 8:31 PM
Yota
Joined Feb 27, '04
From Illinois
true, well those reasons have made me think otherwise about the MR2T. If I went for the 5GC, what parts would I need?
post Sep 23, 2004 - 8:32 PM
jgreening
Joined Jan 17, '04
From Illinois
Yota:
I have to agree with Lagos on the difficulty of the MR2 swap. There are a number of spare parts you will need including the mounts and the alternator bracket for the 5th gen altrac. I searched a long time for that part before I gave up. I believe my mechanic either modified my 5sfe bracket or fabricated one for me. I never did confirm it with him. The tranny mounts in particular involved actual fabrication by my mechanic. Also, I have heard (but have not confirmed) that the wiring is a different and possibly a little more complex. I wish I could help more.
Jay.
post Sep 23, 2004 - 8:34 PM
Yota
Joined Feb 27, '04
From Illinois
J-
Was your reply regarding the MR2T? Or did the modifications to the brackets and mount have to be for the All-Trac?
post Sep 23, 2004 - 8:39 PM
jgreening
Joined Jan 17, '04
From Illinois
MR2T
post Sep 23, 2004 - 8:40 PM
he was talking about the mr2t engine.
for the st185, your really dont have to do much. the hardest part is going to be drilling new holes for the passangers side motor mount, since you have an ST.
you aslo have to decide if you are going to extend your harness or not. for mine, i cut a new hole in the firewall. its something you can only do with the engine out.
This post has been edited by lagos: Sep 23, 2004 - 8:44 PM
post Sep 23, 2004 - 8:46 PM
Yota
Joined Feb 27, '04
From Illinois
which would you recommend? And for the ST185, what parts do I need beside the mounts?
I can still you the MR2T transmission, right?
post Sep 23, 2004 - 8:54 PM
QUOTE (Yota @ Sep 23, 2004 - 6:46 PM)
you mean cutting or extending?
well, cutting is the getto way, but extending is more risky and more work. if you extend the harness, you have to modify every wire that goes into the interrio/ecu of the car. if you mess one of those wire up, you could have major problems that will be almost impossible to track down. if you cut your firewall, then you only have to modify parts of your harness.
post Sep 23, 2004 - 9:02 PM
Yota
Joined Feb 27, '04
From Illinois
What are you achieving by cutting through your firewall? Is it to "cut corners" so the wires will reach to where they need to go?
Is that the safer way?
edit: Is this what they mean by "doing your wiring harness"?
This post has been edited by Yota: Sep 23, 2004 - 9:03 PM
post Sep 23, 2004 - 9:17 PM
hehehe, you need to do more reasearch on wiring.
your harness has to be converted. this is also why you should get an st185 clip. no one here knows how to convert an mr2 harness.
since the harness comes out of a RHD car, it will be too short to fit through the stock hole. you have to extend it or creat a direct path to the ecu by cutting the firewall.
post Sep 23, 2004 - 9:21 PM
Yota
Joined Feb 27, '04
From Illinois
What do you mean by converting? Is it just a matter of getting them to reach?
post Sep 23, 2004 - 9:44 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (Yota @ Sep 24, 2004 - 2:21 AM)
The harnesses are very sensitive. You can't just twist and pull them into "fitting" locations. They should be cut, lengthened or shortened, to match the original factory ones...
post Sep 23, 2004 - 9:50 PM
yota...do a search on swap wiring.
post Sep 23, 2004 - 10:00 PM
boosted_K2
Joined Aug 30, '02
From Michigan
remember, the search function is not working 100% right now, if you cant find what you are looking for use + before each word as an example:
+3sgte +swap +wiring
No but I don't buy it
Cause I'm...
post Sep 23, 2004 - 10:17 PM
Yota
Joined Feb 27, '04
From Illinois
Lagos:
I've been trying searches all afternoon. Nothings coming up...
Boosted:
post Sep 24, 2004 - 11:46 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
It has always been my understanding that the MR2t 3sgte is slightly smaller than the 185 (accessorys not block etc), with the execption of the intercooler piping. The alternator braket should be the only major change and you should be able to use the 5sfe one.. I will check that for you this weekend yota.. hell get some good photos of the MR2t and bring them by and we'll compare with my 3sgte on the physical differences.
as for lengthening the harness.. thats pretty easy to do... just make sure you do one wire at a time instead of hacking the whole thing and then trying to lengthen it.
also I would once agian suggest to you to get the MR2t clip and run a 185 harness on it. I know you can do that with little or no modifications.. theres a guy locally that if I ever get his number agian I'll have him talk to you that had an electrical fire on his MR2t and used a 5th gen alltrac harness to fix it.. think it took him a day or two to get the harness in and working, granted there would be a few changes for the 6gc but still think that would be your best route
post Sep 24, 2004 - 7:00 PM
boosted_K2
Joined Aug 30, '02
From Michigan
i dont think any of the accessories are "smaller" its my understanding they are just mounted more compactly.
Cause I'm...
Lo-Fi Version Time is now: December 4th, 2024 - 4:58 AM
