Failed Emission Test..., ...running too lean |
Sep 25, 2004 - 11:24 AM |
Enthusiast Joined Oct 22, '03 Currently Offline Reputation: 0 (0%) |
I was told by the Smog shop that I was running too lean. They said that I wasnt getting enough air and the Air to Fuel was off by a bit. They said that maybe if I removed the air filter while doing the test it might help for it to breathe better. So I removed it and they ran the test again and the numbers came back 5x worse. I have to get 1.2 reading at the most, with out the filter it ran at 10.0-15.0, and I am currently at 2.08 with the air filter in. They said it might be the Mass Air Flow Sensor. I went to the dealer and they said that my car does not have one. I think it might be my O2 sensor. Can this make my car run lean? I dont want to change them out cuz the previous owner cross threaded the mofos. Where can I start fellas? Any suggestions? Thanks
-Ivan- |
Sep 25, 2004 - 1:13 PM |
Enthusiast Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) |
Try cleaning the O2 sensor.. but isn't running lean too little fuel to too much air? I dunno why they'd want you to put more air in it; thats probably why the results came back worse. You want LESS air in your engine to make the ratio favor gas more.
Also, maybe the sensor thats in the intake? try cleaning that too |
Sep 25, 2004 - 9:57 PM |
Enthusiast Joined Jan 22, '04 From WA, Australia Currently Offline Reputation: 1 (100%) |
yeah i thought lean was gas<air, rich was gas>air...
Sep 26, 2004 - 12:46 AM |
Enthusiast Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
Oh gosh those people are dumb. They tell you you're running lean but yet they tell you to remove the filter to get more air? That makes you run more lean. You should've disconnected the O2 sensor...that'll make you run richer.
Sep 26, 2004 - 2:12 AM |
Enthusiast Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) |
werd, running lean means that theres not enough fuel, and the ratio of fuel to air is not correct with their being to much air. Check your O2 sensors perhaps? I'm not sure I understand why in terms of emissions they would care about you running lean, its more just bad for your engine....
-------------------- AIM : FAQdaWorld
Sep 26, 2004 - 2:13 AM |
come to think of it- wouldn't running lean be good for emissions?
Sep 26, 2004 - 4:19 PM |
Im going to take her to my mechanic. He said he'll run a diagnostic on tuesday. Thanks for the input guys. Weird thing is that I was on the highway a few months back and when I downshifted to 4th to pass a big rig my CEL came on. It read that the secondary O2 sensor was faulty. I reset my codes, replaced the sensor, and it came back after a while. Only seemed to turn on when I hit high RPMs. Now that I reset it again for emissions, I raced the hell out of it to see if the CEL light would come on and it hasnt so far. I've "raced" a 04 Mustang GT, 90 sumtin Firebird or Trans AM, and a GT-S and still no CEL light. Do you think it might have been a clogged injector? I heard that pushin her hard sometimes makes the injectors flow better afterwards.
Sep 27, 2004 - 1:59 PM |
Any other suggestions or thoughts before I take her to the mechanic tomorrow? Thanks for the info so far guys.
-Ivan- |
Sep 29, 2004 - 11:02 AM |
What the hell is going on?!?! I went to get another check and now it's too Rich. I didnt even change anything! Where can I start to check for problems? The CO% is too high and he says its because im runing rich, is this right? He keeps saying that im not getting enought air. What can I check and what parts might I want to get replaced?
Sep 29, 2004 - 11:41 AM |
Latin, get the **** out of that testing station. Find a new one that only does testing, NOT repair. Sounds like they're trying to screw you by getting them to "repair" it.
Sep 29, 2004 - 11:51 AM |
They dont repair. My deadline to have it registered is getting closer.
Sep 29, 2004 - 12:21 PM |
Oh man they dont know what they're doing. Did you bring it to the mechanic or no? If so what did he so? Lets cover the basics in lamens.
Lean = more air than fuel. Rich = more fuel than air. Now taking ur filter off will add air, making it more lean, the more lean, the less fuel is being burned, thus there is less emissions. You have 2 O2 sensors, one in right up top there, and one below, you need to get under ur car to see it. I would suggest making sure both of these are clean and usable. If you are running lean, put some injector cleaner in, maybe ur injectors are a little clogged. -------------------- |
Sep 29, 2004 - 12:43 PM |
Well, he confirmed it is running rich and not lean. I removed the air filter and it ran even more rich. I put in my air filter and I unplugged an O2 sensor and ran a little better, but not good enough. My CEL light wont come on anymore so I cant pull any codes. He keeps pointing at a certain part on my engine that he says I need to check. It's some sort of electric thinggy next to the stock intake right where the hose to the box connects to the motor. I'll get a pic.
Sep 29, 2004 - 12:46 PM |
The battery? jk |
Sep 29, 2004 - 12:59 PM |
Lol, Here
Picture provided w/o permission by: Phat95celigt (let me know if you dont want me to use it) This post has been edited by LatinKraze: Sep 29, 2004 - 1:00 PM |
Sep 29, 2004 - 2:11 PM |
Maybe theres something wrong with ur MAF sensor, but I'd think that if it was unplugged ur car would run leaner because it doesnt sense any air intake.
Also, taking the filter off and having that make it richer doesnt make any sense, and I cant make out what that is. How come he just stood there and pointed, why didnt you ask, hey what is that? or what does that do? Did he stand from far away and point? I am missing something here. -------------------- |
Sep 29, 2004 - 2:52 PM |
Pointing to the EGR system?
Have you messed with your timing any? Might want to check and make sure its 10degrees before top dead center. -------------------- |
Sep 29, 2004 - 4:25 PM |
He called it the mass air flow sensor (MAF i guess). He said it might be busted and is not opening the "valves" therefore restricting the air flow. |
Sep 29, 2004 - 6:37 PM |
Enthusiast Joined Jul 7, '04 From charlotte N.C. Currently Offline Reputation: 0 (0%) |
if your running too rich im pointing at your egr valve.
-------------------- Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph. Next: maybe an elise |
Sep 29, 2004 - 7:18 PM |
That's your TPS in the picture. I think he's reffering to the EGR when he talks about valves opening and closing... -------------------- "It's ok to be naked girl... I'm an artist!"
Lo-Fi Version | Time is now: November 30th, 2024 - 11:16 PM |
