205/50/16, will these mess up speedo ? |
Sep 27, 2004 - 7:49 PM |
will that size tire make the speedo off a bit ?
Sep 27, 2004 - 7:55 PM |
Moderator Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
you should be fine .
-------------------- I will return one day. |
Sep 27, 2004 - 8:44 PM |
No difference in the speedo with those.
Sep 27, 2004 - 8:45 PM |
thanks
Sep 29, 2004 - 10:52 PM |
Enthusiast Joined Jun 2, '04 From NYC Currently Offline Reputation: 0 (0%) |
I am not a expert, but I dont think its a good idea. check tirerack.com or tires.com, I dont think that's a recommanded size for celi, your tires may hit your fender liner when you drive over a pot hole.
Sep 29, 2004 - 10:54 PM |
it should not affect it much.. you have to remember some people ride in 18 inch rims and you hardly hear them complain about rubbing..
Sep 30, 2004 - 7:25 AM |
i have 205/50/16's all around with tein s-tech springs...no rub...could probably put 225/50's
Sep 30, 2004 - 12:20 PM |
Thats cuz with 18's you use 35 - 40mm tires, not 50. 205 is the width of the tire, and the thicker you go the more you need to pay attention to offset, and not rim size. This post has been edited by Supersprynt: Sep 30, 2004 - 12:22 PM -------------------- |
Oct 16, 2004 - 1:35 AM |
Enthusiast Joined Jul 3, '04 From So Calif Currently Offline Reputation: 0 (0%) |
The 205/50-16 will fit just fine. I have those mounted on a Gen 7 GTS wheel and don't have any problems (with stock suspension). The speedo will not be affected either. Check out this site to compare tire sizes:
http://www.miata.net/garage/tirecalc.html |
Oct 18, 2004 - 10:34 PM |
oops, forgot, I had 205/50/16 on my own car... always thinking they were 205/45s...
This post has been edited by Hamster666: Oct 18, 2004 - 10:35 PM |
Oct 20, 2004 - 11:26 PM |
Enthusiast Joined Nov 27, '03 Currently Offline Reputation: 0 (0%) |
I've got 205/55/17's on mine with no problem what so ever. Profile isn't updated with pics yet just to let ya'll know.
Oct 29, 2004 - 2:28 PM |
Enthusiast Joined May 4, '04 From NYC Currently Offline Reputation: 0 (0%) |
just curious, you got it 205/55/17 with lowered body or not? for surely not hitting anything in the wheel well??
Oct 29, 2004 - 4:46 PM |
Mine isn't lowered yet.... and I am damn sure its not hitting a thing.
Lo-Fi Version | Time is now: November 28th, 2024 - 8:12 AM |
