Dangers of Running Rich, 3sgte owners |
Sep 30, 2004 - 12:25 PM |
221 stock. 10-20% loss through the drive train is 177-199. Maximum stock boost is 10-11 psi. I am not raising it from that. I said 10psi, not 12psi (although I do have an aftermarket intercooler....). Bottom line, I am not going to play with fire any more. The pump has been ordered. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Sep 30, 2004 - 12:54 PM |
I've never heard 221 stock, only 225. Now, 10%-20% is HUGE difference, and secondly 20% is way high for FWD and RWD cars. I think Eclipse GSXs get 25% loss and they're AWD. I think that FWD in general avg 12% drivetrain loss and RWD about 14%. That said we'll use the avg of ur numbers for argument sake.
221 x 15% = 188whp. This is why I was asking where you got your figures because you said at 10psi ur expecting 180 at the wheels, when it should be roughly 188 at 8psi. *From what I've heard* its about 7hp per pound of pressure you turn the boost up. Lets say 5, just to prevent overestimation. 231 x 15% = 196whp. Just to see the figures on 12%: 221 x 12% = 194whp. 231 x 12% = 203whp. 256 @15psi x 12% = 225whp. But bottom line is not good using the stock 5sfe pump. This post has been edited by Supersprynt: Sep 30, 2004 - 1:09 PM -------------------- |
Sep 30, 2004 - 5:56 PM |
Enthusiast Joined Dec 2, '02 From Portland, Oregon Currently Offline Reputation: 0 (0%) |
you had the stock n/a pump when you fried your piston, devil? |
Sep 30, 2004 - 6:26 PM |
The JDM ST185 3S-GTE is rated at 225 PS, which is approximately 221.9 horsepower. Anyway, good discussion...I'm learning a lot. -------------------- New Toyota project coming soon...
Oct 4, 2004 - 4:42 PM |
http://www.mr2oc.com/showthread.php?s=&threadid=55214
Walbro a NO NO! After reading through this <very long> article(s) I dont kno if im putting in this walbro because it seems to mess around with the fuel rail and cause pressure drop. This can lead to running rich in some cylinders, destroying them. N/A pump results: http://www.mr2oc.com/showthread.php?s=&thr...hlight=pump+dog This post has been edited by Supersprynt: Oct 4, 2004 - 5:27 PM -------------------- |
Oct 4, 2004 - 7:21 PM |
so.... if fuel pressure is controled by the injectors and the ecu, why do people get FPRs and we dont.
Oct 4, 2004 - 11:18 PM |
we do have FPRs, stock FPRs.
Oct 5, 2004 - 1:47 PM |
The way I interpret that thread on mr2oc.com is that the fuel pressure drop across the rail is bad for tuning. If you were to try to tune for a 11.5/1 afr, the afr is an average figure for all 4 cylinders. The fuel pressure drop across the rail means that some of the cylindars are more rich and some are more lean. The good news is that our engines run exceedingly rich. So, while I probably wouldn't do aggressive (or really any) tuning prior to a rail upgrade, I do not think merely adding the Supra TT pump and retaining the stock 440's is going to cause the problems set forth in that thread. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Oct 10, 2004 - 12:30 AM |
Enthusiast Joined Jul 25, '03 From Santa Barbara, CA Currently Offline Reputation: 0 (0%) |
What's the danger in having it so rich that the engine stalls? My car (91 MR2t) has been doing this, but it only stalls sometimes. Usually the RPMs will just jump up and down for a few seconds, then even out at the normal idle state. However, on rare occasions it will stall. I think I'm beginning to figure out the problems my car has been having. It has 550cc injectors with a Supra fuel pump, but NOT an upgraded fuel rail. I've heard the upgraded fuel rail is vital after upgrading the fuel pump and injectors. I'm trying to find out if this is the missing piece to the problem. The S-AFC supposedly (i.e. according to the seller) was tuned correctly when I bought the car. But on that setting, the car would not go past 4k RPMs (but idles fine). Then when I set it to the other data file (i.e. the default setting) it ran fine, except for the low/jumping idle. What I'm thinking is: a) The S-AFC is tuned for the 550cc injectors, but having the stock fuel rail is causing it to not go above 4k RPMs, or b) The S-AFC is not tuned correctly. Any ideas? |
Oct 10, 2004 - 3:30 AM |
Yeah you have to know what you're doing to get those piggyback systems to run correctly. I suggest either get a fuel rail, learn how to tune it yourself, take it to a tuner, or go back to the factory injectors and pump with the rail you have.
Oct 10, 2004 - 4:15 PM |
The problem is the previous owner didn't give me the stock fuel injectors and pump, or I would totally go back to those because there's no reason for my car to have those uprgades. So, I've already ordered the Wolfkatz fuel rail, and hopefully that will help. After I install the fuel rail, I'll try the original S-AFC setting that was supposedly tuned correctly and see if that works. If not, I'll just have to get it re-tuned. |
Oct 15, 2004 - 3:17 PM |
I just thought I would share this answer to my original question about whether it is dangerous to run rich:
This is from tuner Ricky B on mr2oc.com, operator of MR Controls and author of the 3sgte Power Primer. Good source. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Lo-Fi Version | Time is now: November 25th, 2024 - 6:33 AM |
