3sgte downpipe |
3sgte downpipe |
Sep 29, 2004 - 2:17 PM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
hi i'm wondering if i could put the 3sgte downpipe onto the stock 5sfe catalytic converter. is this possible at all or will i have to get one custom made. thanks guys.
rick -------------------- |
Sep 29, 2004 - 2:18 PM |
The exhaust manifolds are different, it wont work.
This post has been edited by Supersprynt: Sep 29, 2004 - 2:19 PM -------------------- |
Sep 29, 2004 - 2:45 PM |
do you mean the bottom of the downpipe that connects to the 5sfe cat is different?
This post has been edited by rjbibeau: Sep 29, 2004 - 2:45 PM -------------------- |
Sep 29, 2004 - 2:46 PM |
no thats the midpipe, the exhaust manifold is what comes off the engine, and connects to the DP, and then to the midpipe, and the the rest of the exhaust. It wont bolt up because the 3s has a turbo, It will physically bolt up to the midpipe but it doesnt matter.
Sep 29, 2004 - 2:53 PM |
allrigtht i see the manifolds are placed in different places allright thanks. but the downpipe will physically bolt up to it but it can't be used because of placement.
This post has been edited by rjbibeau: Sep 29, 2004 - 2:56 PM -------------------- |
Sep 29, 2004 - 2:57 PM |
If you have a 3s manifold of course the 3s DP will bolt up, I didnt kno you had a 3s manifold.
The 3sgte DP will bolt up to the mid pipe (flex pipe) on the 5s, although they are different diamters (unless you go custom). This post has been edited by Supersprynt: Sep 29, 2004 - 3:02 PM -------------------- |
Sep 29, 2004 - 3:00 PM |
but the cat comes apart on the 5sfe and the 3sgte that's what i was wondering is it could be interchanged.
This post has been edited by rjbibeau: Sep 29, 2004 - 3:01 PM -------------------- |
Sep 29, 2004 - 3:03 PM |
I think we confused the hell outta eachother, but I would think that if you had all the 3s pieces the cat,elbow and dp would bolt up to the manifold and it should bolt up to the exhaust but I think the shape of the DP will effect it also.
Sep 29, 2004 - 3:07 PM |
ya your right i knew that it would all bolt up to each other but what i was wondering if i could use the 3s downpipe just the downpipe and no 3s cat that if it were possible to use the 5sfe cat in conjunction with the 3s downpipe just the elbow part.
Lo-Fi Version | Time is now: December 4th, 2024 - 1:10 PM |
