> 2 bar map sensor
post Sep 30, 2004 - 3:32 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
allright i got ahold of a map sensor from a guy from the mr2 boards. when i wnet to hook it up without the turbo on yet just to see if it worked.the plug fit nice, but when i went to start the car is was idleing low and jerky then it smelled pretty bad then it just shut off wtf is the deal here. i'm just getting no luck i thought it was supposed to be plug and play. ohh ya the part number of the sensor is
89420-17030 it came from a 93 mr2 turbo
i'm kinda dissappointed cuz i'm so close with the 5sfte project.
This post has been edited by rjbibeau: Sep 30, 2004 - 3:36 PM
post Sep 30, 2004 - 4:04 PM
SlowCelica94
Joined Sep 28, '03
From Bloomington, IN
whats a 2 bar map sensor do and why is it nesscary?
92 Civic hatch B16 - Sold
10th anniv RX-7 - RIP
post Sep 30, 2004 - 10:40 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
bump
post Sep 30, 2004 - 10:43 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
QUOTE (SlowCelica94 @ Sep 30, 2004 - 9:04 PM)
a 2bar map sensor is a sensor that reads boost and vucam pressure. it can be turbo mr2 and turbo celica. it is neccessay in turboing a NA celica.
post Sep 30, 2004 - 11:36 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
when i tested this map sensor should i have disconnected the battery... does the ecu store the map sensor info for when it shuts off in it's memory so it uses that last reading in conjunction when the engine gets started up again......
post Oct 1, 2004 - 1:23 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
bump!
post Oct 1, 2004 - 10:36 AM
SlowCelica94
Joined Sep 28, '03
So where's it go? does it attach to a vacuum line?
post Oct 1, 2004 - 6:56 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
yes
post Oct 1, 2004 - 7:03 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
think it maybe has something to do with you not running boost
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Oct 1, 2004 - 8:06 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
do you think so..... has anyone else tried this on their NA celica. or didn't you guys test it before you put the turbo in???
post Oct 1, 2004 - 8:38 PM
kdash
Joined Sep 17, '03
From lakewood, ca
mines work just fine...then again i bought mine brand new from toyota themself for 100 bucks...i work at toyota that's why it's that cheap real price goes to 240
post Oct 1, 2004 - 8:42 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
do you have the same part number as me??
post Oct 1, 2004 - 8:47 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
did you install it before the turbo to see if it worked or did you do it during the install???
post Oct 1, 2004 - 8:50 PM
kdash
Joined Sep 17, '03
From lakewood, ca
i did it before i putted on the turbo just to try it out and then again during putting the turbo in.
post Oct 1, 2004 - 8:51 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
any your car just started right up then huh. what do you think is my problem a bad map sesnor?
post Oct 1, 2004 - 8:59 PM
kdash
Joined Sep 17, '03
From lakewood, ca
i'm not really sure...but i'm pretty sure that the sensor can't be messed up i mean what are the odds of that happening...try it again when you put your turbo on ask other 5sfe turbo guys about this i just recently putted mines on so i only know a little here and there.
post Oct 2, 2004 - 12:12 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
allright thanks for your input though
post Oct 2, 2004 - 12:42 AM
kdash
Joined Sep 17, '03
From lakewood, ca
pm you
post Oct 2, 2004 - 12:47 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
allright thanks.
post Oct 2, 2004 - 1:03 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
QUOTE (kdash @ Oct 2, 2004 - 1:38 AM)
would it be possible to bring the map sesnor to toyota and see if they can test it since you work at toyota????
Lo-Fi Version Time is now: November 24th, 2024 - 7:47 PM
