> noise in reverse
post Sep 30, 2004 - 8:57 PM
red_94gts
Joined Feb 15, '04
From saskatoon, sk
my tranny makes a weird noise while the car is moving and engaged in reverse. while im moving and i shift to neutral. the noise stops. it doesnt make the noise if im not moving. wtf? does this happen to anyone else? can it be fixed?
post Sep 30, 2004 - 9:04 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
is it kinda like a high pitched winding sound?
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Sep 30, 2004 - 9:10 PM
QUOTE (recneps @ Sep 30, 2004 - 7:04 PM)
if yes then its normal.
post Sep 30, 2004 - 9:21 PM
Doge
Joined Dec 2, '02
From Portland, Oregon
yeah reverse gears are straight unlike the angled forward gears. the benefit of having straight gears is they are alot more durable and you dont get as much power loss, but its noisy... thats why only race cars have straight gears... lots of power to the wheels but noisy as hell!
post Sep 30, 2004 - 10:49 PM
red_94gts
Joined Feb 15, '04
From saskatoon, sk
yeah there is the high pitched noise, then there is a even higher pitched noise on top of the normal noise. it wasn't there a couple months ago
post Oct 1, 2004 - 9:25 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
sure it isn't it?
as you speed up the spur gears clash more and just make more noise.
er, spur = reverse
um, i figured they would last a shorter life, but that the engaged a lot faster like, there is no slipping into the gear, just a straight in kind-of approach...
either way, if it is only in reverse and it stops when you disengage the clutch, then yea...id still say its just the spur gear doing its thing
post Oct 1, 2004 - 11:26 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
um, why do you need to reverse so quickly?
post Oct 1, 2004 - 11:32 AM
Mike
Joined Oct 22, '02
From Toronto
I think its the gear ratio
its a really small one when your reversing to make stalling harder to do.. and plus you ont need to go fast in reverse, but it will accelerate quickly..
post Oct 1, 2004 - 11:50 AM
Consynx
Joined Dec 25, '02
ehem, the bigger the gear the greater the power quickly...
1st BIG, 2nd smaller n such n such
it's a spur gear because the regular gears use the syncros, and with it being a spur gear, it makes it impossibly to throw it into reverse when going forwards., but you should hear a real nice grind if you try it from it trying to connect while moving and not being able to "slide" on because it is not cut at an angle like the others.
post Oct 1, 2004 - 7:59 PM
red_94gts
Joined Feb 15, '04
From saskatoon, sk
QUOTE (Consynx @ Oct 1, 2004 - 2:25 PM)
but it doesnt stop when i put the clutch in. it goes away when physically remove the shifter from the reverse postion.
and its gotten louder in the last month or so. i just really wanted to know if it was going to be a problem. ive never heard it in any other car(other than the normal noise) so i figured something might be wrong.
post Oct 2, 2004 - 4:48 PM
gjunon
Joined Mar 17, '03
From you like to know.
err if your really worried about it go head and change your gearbox oil for some synthetic should help some.
This post has been edited by gjunon: Oct 2, 2004 - 4:48 PM
Lo-Fi Version Time is now: November 27th, 2024 - 8:45 PM
