stock fuel injectors |
Oct 2, 2004 - 1:15 AM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
allright i've been doing some research on injectors and this is the deal i have a turbo setup already with a fmu. i would like to keep the stock injectors which are 5sfe injectors and i did some math and they flow at approximately 20.8 lbs. i have a fmu but it's at a 4:1 ratio. on vortech's site they have a ratio of 10:1 which will flow 19lbs. will this ratio work? eventually i'll be getting 7mge injectors. and i've also searched on fuel pumps and people are running with their stock fuel pumps but i'm assuming thier running their stock injectors. will i be fine with this setup before i throw everything on? any suggestions ?
thank you Rick This post has been edited by rjbibeau: Oct 2, 2004 - 1:17 AM -------------------- |
Oct 2, 2004 - 9:54 AM |
Enthusiast Joined May 18, '04 From Charlotte, NC Currently Offline Reputation: 0 (0%) |
i've always heard of people blowing the fuel pump at least on the st, so they use the 255lph fuel pump
Oct 2, 2004 - 1:04 PM |
allright thanks for the info but i have a gt are they the same pumps?
Oct 3, 2004 - 5:34 PM |
someone yell at me if i'm wrong i think they have the same pump, maybe different injectors, i'm not really sure.
Lo-Fi Version | Time is now: November 28th, 2024 - 11:42 AM |
