4agze tranny for a 7afte engine, what do you think |
Oct 3, 2004 - 6:16 PM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
i 've been thinking about swapping in a 4agze tranny with lsd in to my celica with a 7afte
does any one know how different the gears are ?? and how hard it would be?? -------------------- yea your 3sgte is cool but ill stick to my 7agte
Oct 3, 2004 - 6:20 PM |
Like I mentioned in the other post, I think the gearing is a lot shorter than the 7AFE's stock box, but I can't say for sure either. It could be that the gearing is the same, but the final drives are different, or it could be that the gearing is simply different. Either way, best to try it out and see if you like the power transfer. I personally think shorter gearing would hurt a 7AFTE more than it'll help... but the 4AGZE tranny is a lot stronger. Might wanna try and ask AE92 guys...
-------------------- "It's ok to be naked girl... I'm an artist!"
Oct 3, 2004 - 7:46 PM |
do they even bolt up!??!?!?!?
Oct 3, 2004 - 8:49 PM |
Yes they do... 4"A"GZE... 7"A"FE... -------------------- "It's ok to be naked girl... I'm an artist!"
Oct 4, 2004 - 10:39 AM |
bump
Oct 4, 2004 - 12:15 PM |
so would it do anything for a na 7afe?
Oct 4, 2004 - 12:53 PM |
why put it on a 7afe n/a unless the motor was built like edo's from what i read its a stronger tran and axels + lsd. -------------------- yea your 3sgte is cool but ill stick to my 7agte
Oct 4, 2004 - 1:25 PM |
well lsd is a good thing anyways, and stronger is better anyways even though an na probably couldn't do much damage but gear wise, how it would help/hurt torque in first, ect.... plus plans for more engine work
Oct 6, 2004 - 6:22 AM |
Enthusiast Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
say you get the tranny and goto install it, which clutch setup and axles would one use?
Oct 6, 2004 - 6:26 AM |
Enthusiast Joined Jul 31, '03 From Panama City Beach, FL Currently Offline Reputation: 1 (100%) |
you would have to use the 7a flywheel and clutch.
Oct 6, 2004 - 7:06 AM |
Enthusiast Joined Jul 7, '04 From charlotte N.C. Currently Offline Reputation: 0 (0%) |
does anyone know the fearing on the 4agze tranny?
cause i would think with it being a supercharged engine the gear ratios would be much longer thus slowing down your sotck 7afe. -------------------- Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph. Next: maybe an elise |
Oct 6, 2004 - 9:02 AM |
thats why the title says on a 7af"T"e -------------------- yea your 3sgte is cool but ill stick to my 7agte
Oct 6, 2004 - 10:50 AM |
No... this tranny can hold probably beyond a 224mm flywheel.
Gearing will most likely be shorter. The 4AGZE delivers a good mid-ranged powerband but is not as responsive a motor as the 7AFE in the low-end. Like I mentioned above, I'm pretty certian either the final drive or the gearing will be much shorter. Taller gearing will work for the benifit of a 7AFTE IMO... because of the great low-mid range torque it makes... -------------------- "It's ok to be naked girl... I'm an artist!"
Lo-Fi Version | Time is now: November 24th, 2024 - 4:38 PM |
